RPM Signal
Old Nov 22, 2005 | 09:16 AM
maximamaybe74's Avatar
RPM Signal
Is the speedo sensor on the transmission where the ecu gets the rpm tach signal? casue ive been trying to receive a tach signal for a while and my car still gets no tach signal even from the ecu wire itself. IF anyone has any info let me know. Thank you.
Old Nov 22, 2005 | 02:06 PM
greengrass215's Avatar
tech signal, I think the ecu get the info from ignition system.
Old Nov 22, 2005 | 02:21 PM
Chief Brody's Avatar
I think the ECU uses the crankshaft or camshaft position sensor for RPM. You usually need to calibrate whatever device you are using to receive the RPM signal from the ECU.
Old Nov 24, 2005 | 12:10 AM
aight thanks guys, casue my tach still gets no signal, not even from the ecu itself, and im just trying to figure out where the car recives the signal from. If anyone has anymore infromation on this let me know, casue im picking up my wideband friday with the rpm converter, and I have to find a signal somewhere.
Old Nov 24, 2005 | 01:06 AM
mad-max98's Avatar
i think it's the ref crankshaft sensor the one between the tranny and motor not sure though
Old Nov 29, 2005 | 04:19 PM
killerVQ30DE's Avatar
I thought there was a signal on the back of your tach
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
Maxxx10
Sep 13, 2015 03:16 PM
