Wheel lug nut wont come off
Old Nov 25, 2005 | 08:09 AM
old_G22's Avatar
I need help, i was trying to take my front wheel out,but one lug nut wont come off,it just turns and turns i guess the thread is messed up. I can i get it off?
Old Nov 25, 2005 | 08:11 AM
old_G22's Avatar
plz, how can i get it off?
Old Nov 25, 2005 | 08:37 AM
Chapman99SE's Avatar
can you still drive on the wheel/tire or are you taking it off beacuse it needs to be replaced, if you can drive on it go to a locla tire shop and ask them to hit it with their air wrench, my tire shop once tightened the lugs on my old car so tight that when i went to change the brake pads i bent my lug wrench (kinda cheap), i had to bring it back, have them lossen in with the air wrench, then re tighten it by hand
Old Nov 25, 2005 | 09:04 AM
matty's Avatar
If you have a tourch, heat it up a bit and it will break easier.
-matt
Old Nov 25, 2005 | 10:47 AM
f550maranello2's Avatar
-matt
Uhhh... i wouldnt do that...you will melt the paint on the wheel... just brake off the one that you already have on, then get urself another wheel stud and replace it... no point of struggling with it... (make sure u apply some grease to the stud as well....)
Old Nov 25, 2005 | 10:56 AM
white97gxe's Avatar
If the bolt is stripped then youre screwed. If its on too tight then just use a breaker bar, i had the same problem and i used a pullupbar to get it off.
Old Nov 25, 2005 | 11:06 AM
PAREDLINE's Avatar
Does the entire stud turn? or just the lug nut?
Do you think the threads are stripped? Or the sides of the lug nut?
Nobody can help you if you're this vague.
Old Nov 25, 2005 | 11:21 AM
matty's Avatar
Paint ?? Ive seen a tourch used..its completly safe. Dont hit the wheel with the flame, hit the Lug Nut Only
-matt
Old Nov 25, 2005 | 11:22 AM
nismology's Avatar
I would suggest going at it with an impact wrench like has been mentioned then replacing the lug nut and stud.
Old Nov 25, 2005 | 11:28 AM
speed racer's Avatar
Go to home depot and get yourself a 1" dia. galvanized steel pipe. At least 12 inches long. Put it over the breaker bar and you got yourself all the torque in the world to get that nut off by means of leverage. The pipe shouldn't cost more than $10.00 and its a great investment for future repair work.
Old Nov 25, 2005 | 11:35 AM
mmike4164's Avatar
does the whole lug move ? if so then cut it off and put a new one in, if not and just the bolt move then yes your tread is gone put a screwdriver or other leverage device behind it push the nut forward and loosen. either way your going to have to change the lug. good luck.
Old Nov 25, 2005 | 12:04 PM
ryant35's Avatar
If the lug is not stripped and it's still turning, the teeth that hold the stud in place are probably striped.
I've fixed this before, you'll need an impact gun & a long pry bar (36"-40"). Remove all other lug nuts and use the pry bar to pull the wheel away from the hub, and put pressure on the stud. This should help keep it from spinning in place while you zip off the lug nut with the impact gun. If you try a breaker bar, it won't work, you need the impact action to break it loose with out forcing the stud to spin more.
Just don't pry against the rotor or strut. And make sure the car is very stable on jack stands. Or even better go to a shop, they will have a pry bar & will put the car on a lift. Then get a new stud.
Old Nov 25, 2005 | 08:41 PM
99grnmaxgxe's Avatar
It is probably cross-threaded, break it off and buy a new wheel stud and lug nut for $8 at Autozone, if you can, put it on yourself or go to a shop and have them put it in for you. It should cost around $35 for labor, this has happened to me on 4 lugnuts.
Old Nov 25, 2005 | 09:28 PM
ryant35's Avatar
If it were cross threaded then it wouldn't turn. And you will need to use an impact gun to break it off.
Old Nov 26, 2005 | 10:58 AM
madcatmk2's Avatar
If the lug nut keeps spinning and it doesnt move even if you try bracing it; then try drilling straight into the stud until you reach the nut and try again. It should break off easier with less force needed.
Old Nov 26, 2005 | 12:59 PM
tranz's Avatar
what you can do is start of with drilling a little hole in the middle of the lugnut and keep enlarging it without actually drilling into the stud and soon enough the lugnut will just crack open, i've done it, it worked for me, or just replace the wheel stud
Old Nov 26, 2005 | 03:30 PM
maxima_kid's Avatar
Just keep tighten it til it pops off. You have 5 studs. Minusing one isnt a big deal in a short period.
Old Nov 26, 2005 | 06:26 PM
greenmax95se's Avatar
speaking from experience, i just took my ratchet and kept screwing it in till that bad boy twisted and cracked off then i poped out the stud and replaced it. put some muscle into it, and it should go. if not then take a air gun to it, if you dont own one go to a tire shop.
-rafal
Old Nov 26, 2005 | 06:39 PM
boone's Avatar
You gon' pay what you owe
Here's one that I had to do a few months back.
1. Take all of the other lug nuts off.
2. Slide a hacksaw blade between the back of the wheel and the face of your rotor.
3. Brace the back of blade against one of your good studs and put the teeth against the bad stud. Hold one end of the blade with some vice grips.
4. Use an impact wrench to turn the bad stud against the blade. This ends up cutting through it like it's on a lathe.
Old Nov 26, 2005 | 10:18 PM
maxima_kenny96's Avatar
snap it off get a new stud and lug nut and replace it, then u have new parts...thats what i did with mine, a whole $7 fix. and I got an extra lug.
pretty ones, get acorn not the other one.
Old Nov 26, 2005 | 10:39 PM
sonicrunch's Avatar
old_G22
half the dipsh!ts responding to your thread don't know what the hell they are talking about with the exception of ryant35 and boone. Follow either of their advice.
To the rest of you: the lug is not frozen, the threads are stripped in the middle of the stud and it spins but will not come off since threads remain at the end of the stud and will not engage.
maxima_kid ............ how the hell is he going to tighten it when the threads are stripped? duuuuuhhhhhh
Old Nov 27, 2005 | 12:04 AM
ryant35's Avatar
Originally Posted by sonicrunch
old_G22
Thank you!
Old Nov 27, 2005 | 07:27 AM
MAXRB8's Avatar
ryant35 is on the right track IMO, I've had this happen to me except I didn't have an impact gun I pryed the wheel as far forward as possible and used a hacksaw on the bolt from behind the wheel major PTA! What seemed like hours later and a bucket of sweat it came off and I replaced the stud, good luck.
Old Nov 28, 2005 | 03:58 PM
old_G22's Avatar
Thanks for all your responses, i am sorry, i had to go out of town the day i posted it. I just got back a few hrs ago.I dont wanna torch it,i mite damage my wheels. The stud is not moving, the thread is messed up making the lug nut spin in the same area.I am gonna try to do what boone said,,I hope i have enough space to slide in a hack saw..I will keep yall posted, Thank you very much..
Old Nov 29, 2005 | 02:54 AM
maxima_kid's Avatar
You keep turning til it pops off. If ALL the threads are stripped, the whole thing should slip right off. Ive done this before "duuuuuhhhhhh"
Old Nov 29, 2005 | 06:53 AM
PAREDLINE's Avatar
What kind of wheels do you have? Are the lug nuts open on one end? or are they closed.
The best thing for you to do in my opinion is to get some drill bits and start drilling into the stud from the outside. Get progressively larger until you drill out the entire stud.
If you have enough clearance you can get a nut extractor. These work with an impact wrench. You put the extractor (it looks like a socket) over the nut, put the impact wrench in reverse, and it grips the nut. Then you can pull back on the nut with the extractor over it and it will probably catch the remaining thread and come right out.
I think I got an extractor for 39.99. It's worth the money in your case. You're looking at a major pain in the butt on your hands.
Old Nov 29, 2005 | 07:47 AM
old_G22's Avatar
its raining today. .. I have 17 konig appeals, my lugs are closed ends. thats a good idea, thanks paredline. maxima kid,that should work if i can get it to tighten again,i cant tighten or loosen it
Old Nov 29, 2005 | 09:22 AM
MaximaSE96's Avatar
Maxima Owner
its stripped....u might be lucky and be able to get it off with an impact....it sometimes happens...but if not it might have to be drilled off which is poopy
Old Nov 29, 2005 | 10:11 AM
PAREDLINE's Avatar
Another thing you can do is get a pair of needle nose Vice grips. Try to grip the nut and twist it backwards while pulling trying to get it back on the threads. Hopefully you can re-lodge the threads (even if its cross threaded) enough to get the thing off. If it keeps stripping then just keep pulling back. eventually you'll strip the entire stud.
When you replace the stud get Motormite studs. They are a little longer than stock. I just replaced all my rear studs from Advance Auto Parts for 98 cents a piece.
Old Nov 29, 2005 | 01:55 PM
siballiance's Avatar
where can i get those Motormite studs?
lowpost99
Oct 26, 2025 06:53 PM
camako
Sep 22, 2015 04:27 PM
bumpypickle
Sep 19, 2015 01:07 AM
dcam0326
Sep 8, 2015 11:02 PM
