drive belt pulley fell off while driving
Old Nov 25, 2005 | 01:25 PM
nadir_s's Avatar
vicodin ... gift of life
dunno how on earth this happened .. but basically , i was driving early in the morning and i hear a something hit the bottom of my car and the battery / brake light go on .. i pull over to see if i had a flat tire but didn't. I continued driving home (~3mi) figuring it had to do somethin w/ the drive belt.
came home, got flashlight and took an initial look ... small pulley on the top center of the drive belt setup had apparently come off ... all i see is a screw stud there where it's apparent it had come off ... just need to get another one and put a nut back on.
Do you think any damage done to the alternator or anythin? I noticed the belt was not moving while the engine was running at that point. I figured it'd continue moving, just scraping on that stud ...
pls give me feedback. I need to see if i can locate anotehr one ... damn it looks like a tight spot too to get my hands in there.
ill post pics
Old Nov 25, 2005 | 02:09 PM
nismology's Avatar
You're gonna have to get a new tensioner assembly. Just remember to tighten the nut securely next time.
Old Nov 25, 2005 | 02:27 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Ya just get another idler pully. You can get a new one from pinicle nissan for $39 + shipping, here is a link; http://www.trademotion.com/partlocat...5&model=Maxima
But Im sure there are a few people on here who have extras from parted motors of what not. I know Kelly (Xerox) up in Sac had a 2k motor he was parting out, and UNCdood also has a 2k motor he is parting out (I just bought some heads off him). Its actually pretty easy to replace too, but if you cant do it, there is always Matt.
Old Nov 25, 2005 | 02:30 PM
njmodi's Avatar
Do I get a tax break?
Nah - not likely you did any damage... strange that the pulley came off though... I think the pulley and tensioner are sold as a set. It's a dealer only part.
Old Nov 25, 2005 | 04:49 PM
nadir_s's Avatar
thanks for the feedbck ... i foudn the part at the local dealer and spent 60 for the assembly .. whatever.
Wasn't hard to to install it.
Now ... how do i check the tension? I saw from a prev. thread that the belt should not turn more than 90 degrees ... do u check this from the bottom of the car where u can actually get a good hold of the belt??
Old Nov 25, 2005 | 07:59 PM
matty's Avatar
Should be checked "1/2 way between the A/C pulley and the Main Crank Pulley and the belt shouldnt twist more than 90 degree"...They call it a 90 degree deflection..I check it all time since Im supercharged and needs to be perfect
While your down there it may be a good idea to do the Power steering belt as well...its not too hard
-matt
Old Nov 26, 2005 | 01:07 AM
nadir_s's Avatar
thanks alot guys!
I got the thing to work now. That wasn't too bad at all!
captchaos
Mar 15, 2016 12:18 PM
markevans999
Oct 25, 2015 08:27 AM
Maxie40
Sep 14, 2015 11:28 AM
Maxima30
Sep 7, 2015 06:13 PM
