How many quarts of ATF do I need?
If your only doing a drain and refill, 4 qts (1 gallon) should be fine.
A flush requires a case (12 qts).
Refer to the fluids and lubricants section of this site for more info on changing your tranny fluid. The stickies on that forum has some good information.
^yep. normally there is about 4 quarts in the pan, about 5 quarts in the torque converter and about 1 quart hanging around somewhere. If your just going to drop the pan, your going to need about 4 quarts.
in the lube section they have a write-up on how to do a flush urself on a 4th gen takes about 10-12 quarts pending how clean you want it.
A lot of ppl are against mixing syn and dino oils. But i ask amsoil themselves and they say its prefectly normal. Should be no problem. When it gets warm out, i'm just going to do a drain and fill every month for 3 months and hopefully i'll get out about 75% of the junk fluid.
Originally Posted by FishyMan
im just curious how u get an accurate. reading.
Car on level ground, engine running in park, pull the dip stick and look at the level.
There are 2 marks, one says cold, the upper one says hot. It's always best to check it hot.
foodmanry
Sep 24, 2015 12:02 PM
bill99gxe
Aug 23, 2000 11:28 AM
