Car still lag after clutch!
Old Nov 25, 2005 | 08:09 PM
S15 SR20DET's Avatar
sup guys,
my maxima lags when i try to get on it about half way down, at low RPM maybe 2,500-3,000 RPM. i can say it did it all gears from 2nd to 5th. it would lag hard and shakes then after that it would pick up. i replaced my clutch to a stage 1 exedy and after i broke it in the problem was still there.
i think it might be the fuel filter or the engine mounts. anybody had this problem before.
thanks
Old Nov 25, 2005 | 09:54 PM
Fr33way™'s Avatar
Wild for Width
check for knock sensor code?
Old Nov 25, 2005 | 09:59 PM
i changed the knock sensor about 13k ago
Old Nov 26, 2005 | 12:33 AM
come on guys anybody had that prob before?
Old Nov 26, 2005 | 12:39 AM
joosdawg's Avatar
is there any way to be any more desriptive of what it sounds like its doing? a video would really be awsome in this case lol. Sounds like its either dying out from a lean or rich condition if its the actual engine making the noises and shaking or else somthing happened with the tranny that it doesnt like in gears. Idk Id say first off does it do it at all in first, if you have your hood open and stare at the engine is it smooth or can u see it jump a little? Theres just too many variables to narrow that down to one specific thing without knowing more details if at all possable. Also if its engine it sounds fuel related so why not just spend under $10 and get a new fuel filter put in there and see if that was the case ?
-Ryan
Old Nov 26, 2005 | 12:47 AM
there is no sound coming from the engine i can tell u that, the engine looks like its running smooth when i have the hood open and it doesnt do it in 1st. it feels like the car is cutting off and then it catches its breath again around 3,500 rpm, and i can take it all the way to red line with no problem. i also get madddd wheel hop when i shifted into second gear.
Old Nov 26, 2005 | 05:08 AM
njmaxseltd's Avatar
Sounds like a MAF or coil pack problem.
Old Nov 26, 2005 | 07:15 AM
tomservo291's Avatar
did you adjust your clutch pedal at any point?
Old Nov 26, 2005 | 09:10 AM
the mechanic installed the clutch, but i am positive he didnt mess with the pedal
Old Nov 26, 2005 | 09:21 AM
chilled's Avatar
Sounds like the MAF. Go to the junkyard and buy a MAF cheap, I only payed $10 for mine. (Also smuggled 6 coil packs, ks, boost sensor, and other goodies)
Old Nov 26, 2005 | 09:33 AM
yea, but if the MAF was bad it wouldnt rev over 3k. my friend has an 03 altima and when his MAF went out on him it wouldnt go over 3k at all.
Old Nov 26, 2005 | 09:34 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
is it just me or does everyone just say check knock sensor a lot. You could get a scantool and record maf voltage or get a lab scope and draw a waveform. or you could check TPS voltage and waveform also.
Old Nov 26, 2005 | 09:49 AM
i dunno how much voltage it should be on, and what if its at low voltage. what it could be?
Old Nov 26, 2005 | 10:57 AM
njmaxseltd's Avatar
The above only happens when it's completely dead.
If it's slowly going out of calibration, you'll have engine performance problems before the ECU even detects it.
Old Nov 26, 2005 | 11:02 AM
Nealoc187's Avatar
SLOW
Sounds like coilpacks to me. What makes you think it is something mechanical like the clutch or motor mounts. Neither of those would create the symptoms you are experiencing...
Old Nov 26, 2005 | 11:29 AM
so, it sound like most of you are saying it's coilpack problem. if it is, do they sell any high preformance ones,and where i can get it from?
thanks
Old Nov 26, 2005 | 03:35 PM
anybody knows?
Old Nov 26, 2005 | 03:42 PM
Nealoc187's Avatar
SLOW
There is one brand of aftermarket coilpacks which have not yet been tested, so no one knows if they give gains or not. They cost something like $400-600 and as far as I know are only available from Japan. Just get regular coilpacks unless you want to guineapig something and have money to burn.
Old Nov 26, 2005 | 03:50 PM
maxima_kid's Avatar
Yea, lag with this type of symptoms has nothing to do with mechanical. Most likely electrical.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Give him your best offer. If he accepts, let me know. I need a set too.
Old Nov 26, 2005 | 04:00 PM
thanks for the link MAXIMA KID
Old Nov 26, 2005 | 08:19 PM
maxima_kid's Avatar
Yea dont worry about it.
Lakersallday24
Jun 16, 2019 01:35 AM
maxima-junky
Aug 13, 2015 09:59 AM
MikesChevelle
Aug 10, 2015 10:53 AM
sc10692
Aug 9, 2015 09:37 AM
