Need rear calipers...Advice...
Old Nov 27, 2005 | 10:34 AM
MaxMateo5's Avatar
I think my rear passenger side caliper is hanging up... I had that smell the other day and it was really HOT! compared to my others... Happened to me on my 98 about a year ago, replaced one then the other went 500 miles later. Can someone tell me where to get two rear calipers at for a 95 max, I just got new brake pads and rotors also, is it possible that this one is alittle off and can be adjusted?? Thanks
BTW- I would like to know opinions on calipers and where to get them anyways...
Old Nov 27, 2005 | 12:56 PM
njmaxseltd's Avatar
The rear calipers on our cars are prone to failure.
Try your local auto parts store, AutoZone carries them.
Replace both for even rear braking performance.
Old Nov 27, 2005 | 01:55 PM
MaxMateo5's Avatar
Cool, thanks for the tip... and I paid $190 for my last rear caliper so I am atleast going to try to beat that.. Are these difficult to install?? Is it just like changing brake pads??
Old Nov 27, 2005 | 02:19 PM
njmaxseltd's Avatar
Pretty simple, just 2 bolts. Remove, clean and lube the guide pins when you change the caliper. You'll have to bleed the brakes really good after opening the system.
Old Nov 27, 2005 | 08:20 PM
KRRZ350's Avatar
$100 for two used calipers from a low mileage 98, includes shipping, pm me if interested, thanks.
Old Nov 27, 2005 | 08:22 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
That's Pretty good deal. Do they work?
Old Nov 27, 2005 | 08:44 PM
A Flood99's Avatar
i got 2 new rears from derrick about 6 monthes ago for 160 shipped
pm him and see if he still has the hook-up
Old Nov 28, 2005 | 10:58 AM
njmodi's Avatar
Do I get a tax break?
www.partsamerica.com, 80 bucks a piece for reman rear calipers (you return your old ones for core credit).
Old Nov 28, 2005 | 07:59 PM
JUDE's Avatar
I was quoted $40 for the part & $75 for the labor for the Right Rear Caliper from Pep Boys. Midas quoted me $140 parts & labor plus an extra $50 for bleeding.
Can't beat that pep boy price.
Old Nov 28, 2005 | 09:04 PM
MaxMateo5's Avatar
thanks for the advice... gonna go back to where I just got the brakes done to get a free inspection.. see what kind of price they offer..
Old Nov 29, 2005 | 06:17 AM
90stanza's Avatar
Same thing happened to me, I came home from college and went to drive my car for the first time in months and the rear driver side caliper was/ still is stuck.
Old Nov 29, 2005 | 08:25 AM
slag's Avatar
I just ordered one today from autozone. $59.99 plus a $62.00 core charge, reman unit.
This is unloaded so i also bought pads and a new rotor. Yep, mine was hangng up on the way into work today so bad that i had to turn around after a few blocks and return home and drive my truck in.
Old Nov 29, 2005 | 09:23 AM
madcatmk2's Avatar
Is this failure prone to stock calipers only or do aftermarket and stock fail all the same?
Old Nov 30, 2005 | 07:30 AM
slag's Avatar
dont know, but in my case, it wasnt the piston that failed, but rather the sliding rods that move back and forth were all gunked up with crud. I cleaned them all up and cleaned the holder for them with brake cleaner, brushed it all out, dried it, then used high temp grease on the rods. Chances are thats whats wrong with most people whose calipers are sticking.
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
bbsitum
Sep 11, 2015 04:55 PM
