Somethings wierd is happening to my car
Old Nov 27, 2005 | 07:12 PM
hdiggeddy's Avatar
My car has been driving very strange lately. When I shift into 2nd and give it full throttle my car jerks. Same thing when I do that with 3rd. Its kind of wierd any inputs? I know my coils are all good, timings good (cam, crank sensors), knock sensors good.
Old Nov 27, 2005 | 07:25 PM
1996blackmax's Avatar
Have you checked your tranny fluid?
Old Nov 27, 2005 | 08:24 PM
hdiggeddy's Avatar
yes, it is fine. But the clutch smells a little after everytime i drive it. It still grabs pretty good though.
Old Nov 27, 2005 | 08:28 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Maybe you are not Shifting Properly.
Old Nov 27, 2005 | 08:34 PM
hdiggeddy's Avatar
I am shifting properly but my flywheel needs to be resurfaced. I can feel the shakeyness of it. I am thinking my car needs a new injector? I think its number 3, im not sure though.
Old Nov 27, 2005 | 08:35 PM
99grnmaxgxe's Avatar
Your clutch is probably on it's last breath, you should go get it checked out to be safe and certain.
Old Nov 27, 2005 | 08:36 PM
CystumMax's Avatar
well, if you car needs a new injector, do you think your clutch would smell?
Old Nov 27, 2005 | 08:40 PM
hdiggeddy's Avatar
no but someone said something about my tranny. So i brought up the clutch problem....... and i dont know how a jerkyness could be caused by a transmission. It was just getting off topic
Old Nov 27, 2005 | 08:43 PM
CystumMax's Avatar
Jekyness can be caused by a bad or a worn clutch. If your Injector goes bad, your engine will MissFire and you will get a lot of engine Shake, And it feels like you are driving a Kia.
Old Nov 27, 2005 | 08:49 PM
hdiggeddy's Avatar
yea, i think its time for a new clutch. any suggestion for daily use and occasionally track.
Old Nov 27, 2005 | 09:06 PM
CystumMax's Avatar
http://www.customenterprise.com/view.../vts/design017
I could be wrong, wait for others to give feed backs, but I hear good things about this brand.
http://www.customenterprise.com/view...asd/scspid/536
Old Nov 28, 2005 | 08:12 AM
IMO, CE is too expensive, you should just go with stock parts unless you are serious about power.
Old Nov 28, 2005 | 02:18 PM
LeVeL's Avatar
My auto's shifts are a bit jerky under medium-to-hard acceleration, 1st to 2nd and 2nd to 3rd. Clutch you recon?
Old Nov 28, 2005 | 02:57 PM
chk34kk's Avatar
My car does the same exact thing, and especially when it is cold outside. The problem wears off as the car heats up.
Old Nov 28, 2005 | 03:47 PM
JUS10's Avatar
That Is Wired
Old Nov 28, 2005 | 05:51 PM
hdiggeddy's Avatar
i talked to a mechanic today and he said that it would not be the clutch making the jerking. He said if the clutch was bad, it would not engage properly. He said try going from 1st to 3rd gear and if the RPM's jump and go back down then i would need a new clutch. The problem is most likely a misfire.
Old Nov 28, 2005 | 06:48 PM
CystumMax's Avatar
It could be a bad Fuel Injector, but in most cases you will get a SES light. Scan the computer to retrieve the codes before opening a Thread.
That should give you enough to start with, and if you don't find any codes, go to another mechanic.
Good Luck.
Old Nov 28, 2005 | 06:49 PM
CystumMax's Avatar
The TCC solenoid is located in the transmission on the valve body. To verify that this is causing your problem, disconnect the four wire plug that plugs into the side of the transmission and drive the car. If your problem is cured, replace the solenoid.
Old Nov 28, 2005 | 07:18 PM
97SEdriver's Avatar
this place is dead
What in the hell is that speaker thing in your sig? Is that a human hand or a little kids?
Old Nov 28, 2005 | 07:41 PM
hdiggeddy's Avatar
computer was scaned and had no codes.
Old Nov 28, 2005 | 08:29 PM
MorpheusZero's Avatar
repeat after me: "AN AUTOMATIC TRANSMISSION DOES NOT USE A CLUTCH."
Old Nov 29, 2005 | 07:40 AM
tomservo291's Avatar
if you're looking for a new clutch you can get a 00/01 5th gen pressure plate, friction disc and throw out bearing from forum member DAVEB for 191 + shipping... send him a PM and he will give you contact information...
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
egali045
Aug 16, 2015 01:19 PM
MikesChevelle
Aug 9, 2015 11:50 AM
acw
Aug 7, 2015 04:20 PM
