SE-L, 5th gear while flooring it
Old Nov 27, 2005 | 10:46 PM
Thahman's Avatar
When I push the pedal all the way to the floor while in 5th gear, I get some hesitation, then the service light blinks 4x???
Possibilities:
Fuel filter, injectors, coil pack going bad? spark plug?
Old Nov 27, 2005 | 11:00 PM
975spEEd's Avatar
sounds like a misfire, probably a coil pack.
Old Nov 28, 2005 | 05:50 AM
MaDMvD's Avatar
Almost willing to bet it's bad coilpacks.
Old Nov 28, 2005 | 06:18 AM
wikidminds's Avatar
the infamous 1999 maxima coil packs at its best again!
Old Nov 28, 2005 | 06:57 AM
Thahman's Avatar
Damn those coil packs, it would make things so much easier if they weren't so difficult to test... meaning, NOT having to individually use a OHMeter.
::grin::
Old Nov 28, 2005 | 07:05 AM
MaDMvD's Avatar
What exactly is the value/range of a good coil pack, in ohms?
Old Nov 28, 2005 | 09:56 AM
1FSTMAX's Avatar
lol damn same ish happend to me... cyl#1 coil pack was bad.. grr..
Old Nov 28, 2005 | 10:08 AM
JwaxMax99's Avatar
Haynes manual gives the values. Also, you need to need to test between the right pins, there are 3 to chose from.
Old Nov 28, 2005 | 11:13 AM
1FSTMAX's Avatar
one note*
my coil problem was intermittent.. i checked it with a fluke, and it was fine. But when the coil was put under load it wouldn't work, or some times it would.
Old Nov 28, 2005 | 05:08 PM
Thahman's Avatar
Originally Posted by 1FSTMAX
one note*
That's exactly it. BINGO! :-P
user 11122324
42
Jul 18, 2022 03:35 PM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
