Replace clutch hydrolic system?
Old Nov 28, 2005 | 06:54 AM
matts95max's Avatar
Replace clutch hydraulic system?
I have a 95 5spd. I just recently got my transmission rebuilt at nissan and had a new clutch put in at the same time. The clutch was a spec stage 2. My mechanics at nissan told me I need to now replace my clutch hydraulic system because the pressure from the pressure plate is too much for what I have now. The clutch has to be like on the floor for me to shift and then about an inch off the floor is where is lets out.The clutch is not dissengaging everytime due to the pressure leaks. He was saying the master and slave cylinder being so old with the new pp putting more pressure on the system is causing the leaks to not hold enough pressure to push back. He said the seals get old and as soon as I replace the slave, master, and one of the lines that is leaking it will be fine. Is this true? also I really like how the spec clutch grabs tho I heard its not goin to last long..is that true also? Thanks guys - Matt
Old Nov 28, 2005 | 06:59 AM
Thahman's Avatar
Hey I just had my tranny rebuilt / clutch and I'm having the same prob, clutch lets out about 1" from the floor, not the normal sensitivity. Not sure how to go about doing that though.
Old Nov 28, 2005 | 07:09 AM
matts95max's Avatar
hmm maybe some1 who had the same prob found an answer..? help..
Old Nov 28, 2005 | 09:00 AM
sonicrunch's Avatar
hydrolic?
hydraulic..(please tell me you didn't graduate high school)
The anwer is: replace the clutch master and slave cylinders.
Old Nov 28, 2005 | 10:51 AM
matts95max's Avatar
thanks man
Old Nov 28, 2005 | 10:57 AM
tavarish's Avatar
fwd gone rwd cr00
the master cylinder should be fine, just make sure there are no leaks in the line. Also, being a hydraulic system, it has to be bled, and our cars have a upper and lower bleeder. You could try bleeding the system, and seeing if that works. i would definitely upgrade the lines with stainless steel ones though.
Old Nov 28, 2005 | 03:50 PM
JUS10's Avatar
That Is Wirede
Old Nov 28, 2005 | 03:51 PM
JUS10's Avatar
I Have A Manual
CorollaULEV
30
Aug 9, 2021 08:11 PM
rbuswell
Nov 17, 2016 04:54 AM
stromm
Aug 27, 2015 04:13 PM
vanebecker
Aug 17, 2015 08:24 PM
kirkhilles
Aug 8, 2015 10:53 AM
