ses: o2, bank 1 sensor 2. need info
Old Nov 30, 2005 | 12:23 AM
sook's Avatar
what does this o2 sensor control?
how urgent is it that i replace it?
is it okay to buy a used one?
how many miles should i look for on it?
how much should i expect to pay?
is $50 labor too high for install?
Old Dec 3, 2005 | 02:17 AM
maximaman10's Avatar
It is the second sensor on the firewall side. the one closed to the cat. The sensor will be about $100.00 and you should be able to put it in yourself. What is the trouble code?These are all the Code Scanner Codes Converted fron the Haynes Manual
Scan Tool Trouble Code --- Check Engine Light flash code
P0000 --- 0505
P0100 --- 0102
P0105 --- 0803
P0110 --- 0401
P0115 --- 0103
P0120 --- 0403
P0125 --- 0908
P0130 --- 0307
P0130 --- 0503
P0131 --- 0411
P0132 --- 0410
P0133 --- 0409
P0134 --- 0412
P0135 --- 0901
P0136 --- 0707
P0137 --- 0511
P0138 --- 0510
P0139 --- 0707
P0140 --- 0512
P0141 --- 0902
P0150 --- 0303
P0151 --- 0308
P0152 --- 0415
P0153 --- 0414
P0154 --- 0413
P0155 --- 0101
P0157 --- 0314
P0158 --- 0313
P0159 --- 0708
P0160 --- 0315
P0161 --- 1002
P0170 --- 0706
P0171 --- 0115
P0172 --- 0114
P0173 --- 0806
P0174 --- 0210
P0175 --- 0209
P0180 --- 0402
P0300 --- 0701
P0301 --- 0608
P0302 --- 0607
P0303 --- 0606
P0304 --- 0605
P0305 --- 0604
P0306 --- 0603
P0325 --- 0304
P0335 --- 0802
P0340 --- 0101
P0400 --- 0302
P0402 --- 0306
P0403 --- 0515
P0420 --- 0702
P0430 --- 0703
P0440 --- 0705
P0443 --- 0807
P0443 --- 1008
P0446 --- 0903
P0450 --- 0704
P0500 --- 0104
P0505 --- 0205
P0510 --- 0203
P0600 --- 0504
P0605 --- 0301
P0705 --- 1003
P0705 --- 1101
P0710 --- 1208
P0720 --- 1102
P0725 --- 1207
P0731 --- 1103
P0732 --- 1104
P0733 --- 1105
P0734 --- 1106
P0740 --- 1204
P0744 --- 1107
P0745 --- 1205
P0750 --- 1108
P0755 --- 1201
P1105 --- 1302
P1148 --- 0307
P1168 --- 0308
P1220 --- 1305
P1320 --- 0201
P1335 --- 0407
P1336 --- 0905
P1400 --- 1005
P1401 --- 0305
P1402 --- 0514
P1440 --- 0213
P1441 --- 0801
P1444 --- 0214
P1445 --- 1008
P1446 --- 0215
P1447 --- 0111
P1448 --- 0309
P1490 --- 0801
P1491 --- 0311
P1492 --- 0807
P1493 --- 0312
P1605 --- 0804
P1705 --- 1206
P1706 --- 1003
P1760 --- 1203
P1900 --- 0208
P1900 --- 1308
95–00 MAXIMA
P0000
No Self Diagnostic Failure Indicated
P0100
MAF Sensor
P0105
Absolute Pressure Sensor
P0110
IAT Sensor
P0115
ECT Sensor
P0120
TP Sensor
P0125
ECT Sensor
P0130–P0134
Front HO2S Bank 1
P0135
Front HO2S Heater Bank 1
P0136–P0140
Rear HO2S
P0141
Rear HO2S Heater
P0150–P0154
Front HO2S Bank 2
P0155
Front HO2S Heater Bank 2
P0157-P0160
Rear HO2S Bank 2
P0161
Rear HO2S Heater Bank 2
P0170
Fuel Injection System Function
P0171
Fuel System Lean Bank 1
P0172
Fuel System Rich Bank 1
P0173
P0174
Fuel System Lean Bank 2
P0175
Fuel System Rich Bank 2
P0180
Tank Fuel Temperature Sensor
P0300
Multiple Cylinder Misfire
P0301–P0306
Cylinder Misfire
P0325
Knock Sensor
P0335
CKP Sensor
P0340
CMP Sensor
P0400
EGR Function
P0402
EGRC-BPT Valve
P0403
EGR Volume Control Valve Circuit
P0420
TWC Function RH Bank
P0430
TWC Function LH Bank
P0440
EVAP Small Leak
P0443
Canister Purge Control/Solenoid Valve
P0446
Vent Control Valve
P0450
EVAP System Pressure Sensor
P0500
VSS
P0505
IAC-AAC Valve
P0510
CTP Switch
P0600
A/T Communication Line
P0605
ECM
P0705
PNP/Inhibitor Switch
P0710
Fluid Temperature Sensor
P0720
VSS
P0725
Engine Speed Signal
P0731
A/T 1st Signal
P0732
A/T 2nd Signal
P0733
A/T 3rd Signal
P0734
A/T 4th Signal Or TCC
P0740
TCC Solenoid Valve
P0744
A/T TCC Signal
P0745
Line Pressure Solenoid Valve
P0750
Shift Solenoid Valve ‘‘A’’
P0755
Shift Solenoid Valve ‘‘B’’
P1105
MAP/BARO Switch Solenoid Valve
P1130
Swirl Control Valve Control Solenoid Valve
P1148
Closed Loop RH Bank
P1165
Swirl Control Valve Control Vacuum Check Valve
P1168
Closed Loop LH Bank
P1220
FPCM
P1320
Ignition Signal Primary
P1335
CKP Sensor (REF)
P1336
CKP Sensor
P1400
EGR Control Solenoid Valve
P1401
EGR Temperature Sensor
P1402
EGR System
P1440
EVAP Small Leak
P1441
VC/V Bypass Valve
P1444
Purge Volume Control Valve
P1445
P1446
Vent Control Valve
P1447
EVAP Purge Flow Monitor
P1448
Vent Control Valve
P1490
Vacuum Cut Valve Bypass Valve
P1491
Vacuum Cut Bypass Valve
P1492
Purge Control Valve Solenoid Valve
P1493
Purge Control Valve & Solenoid Valve
P1605
A/T Diagnosis Communication Line
P1705
TP Sensor
P1706
Park/Neutral Position Switch Circuit
P1760
Overrun Clutch Solenoid Valve
Old Sep 21, 2008 | 04:05 PM
Problemchild1one's Avatar
i have p0750 what can i do is it bad wat can i do? how do i fix it and non-tech language please lol nah forreal i need help please
Old Sep 21, 2008 | 05:44 PM
pmohr's Avatar
No more Maximas...
Did you search?
Still on the original solenoid pack? Nissan has a TSB kit out to replace them. Get it, replace the solenoids, problem solved.
Before that you may want to check the wiring harness.
Why the hell would you bump a 3 year old completely unrelated thread?
Old Sep 22, 2008 | 06:57 PM
JY05's Avatar
yoyo
you should get that o2 sensor fixed because that basically makes your car run really slow than what it should be running.. and also it makes your car wastes much more gas than usually.. if you have time i suggest you check your knock sensor as well.. since those break in the 4th generation model frequently
Old Sep 22, 2008 | 06:59 PM
pmohr's Avatar
No more Maximas...
Two year old thread, seriously.
Also, B1S2 is post cat, doesn't do a damn thing.
Old Sep 23, 2008 | 07:22 AM
wxm's Avatar
wxm
You will definitely need to get it fixed before the next inspection.
Anyway, it is not too hard to do yourself, although you will need a special O2 socket, and be prepared that it could be very tight and hard to remove.
Old Sep 23, 2008 | 07:25 AM
pmohr's Avatar
No more Maximas...
I swear...
Old Nov 3, 2008 | 09:33 PM
eastvan's Avatar
P0150 - o2 Sensor
Hi All,
I was just reading this thread, and saw this discussion, which is the same problem I have been having with my '97 Maxima 5speed.
I had this code appear when my engine light went on. I have put in three new 02 sensors, the first two being aftermarket, the third being a Nissan OEM one. Every time I put one in, after about four or five days, the light comes back on.
Any idea on what issues in the background could be causing this?
Makes the car very hard to drive smoothly, and the fuel mileage is lousy.
Old Nov 3, 2008 | 09:38 PM
pmohr's Avatar
No more Maximas...
Originally Posted by eastvan
Hi All,
Have you tested all the sensors to see whether or not you just happened to get 3 faulty oxygen sensors? Tested the wiring at all?
Repeatedly throwing parts at it is generally the last resort, not the first.
Old Jul 3, 2012 | 11:36 AM
Maxima"00"'s Avatar
I have a 2000 nissan maxima and the check engine turns on. It hasn't turn off. I went to Auto zone to see what the problem was and they gave me 3 receipts. 2 of the troubleshooting said: P0139 and P1126. What should I do to get it fixed?
Old Jul 3, 2012 | 11:40 AM
ShocknAwe's Avatar
Its truly a DIY job. You can use the scissor jack that came with the car, go to wal-mart and get yourself some $20 jack stands to save your life, use some penetrating oil such as PB blaster and it should come off fairly easily. Unless you have rust problems where you live then it could become a pain and some heat will be required. Buy a good o2 sensor ($40 or more) and save yourself some money. Its not hard promise!
spencerwh1
Jun 30, 2016 05:44 AM
hayne
Oct 5, 2015 11:53 AM
Max139617
Sep 29, 2015 06:44 PM
220k+ A32
Sep 11, 2015 02:18 AM
