WTF Could Be Wrong Now: Kinda Long , Sorry
Old Nov 30, 2005 | 10:10 AM
Wil's95SE's Avatar
我爱台湾
Okay guys I was having problems with the Max, seems as though she wasn't getting enough gas and the car would sputter and had a loss of power. Turned out to be a bad fuel injector, okay great no problem. So I had them all replaced just in case there was a chain effect. Also had all the coilpacks checked (no issues) and went back to platinum sparks vice coppers (NGK of course). Now I have another problem, when the car is cold or hot (doesn't matter), she has a hard time turning over. You can hear it trying to crank up but the engine makes a hesitation sound or as I say a hard scrape sound and the engine shakes (possibly motor mounts, I know). I not only have to depress the clutch in but also give it a little gas to get her going and that doesn't even work sometimes I have to let her sit for a minute cause you can smell gas in the exhaust from trying to crank it up. Doesn't sound like it's a starter problem cause the car does stay crank when running and does actually attempt to turn over when starting. Cleaned out the throttle body really good and ran a bottle of Chevron through her to make sure nothing else was clogged. What else could it be fellas? I am at a loss. The only code I'm throwing is for the air intake temp sensor cause it's unplugged. Otherwise she is code free. Please help.
Old Nov 30, 2005 | 10:33 AM
dgeesaman's Avatar
Maintenance Monster
Engine Coolant Temp Sensor is my first guess. I'm not sure if/why it's not posted a CEL code though.
Dave
Old Nov 30, 2005 | 11:20 AM
njmodi's Avatar
Do I get a tax break?
Why not plug the IATS back in?
If your're smelling gas, you've likely flooded the engine - so thats why it gets harder to start at that point. Put the pedal to the floor (throttle wide open) then start the car - it helps clear the flooded engine. You may also want to check your oil (fuel may have seeped in due to the flooding).
Old Nov 30, 2005 | 01:09 PM
Wil's95SE's Avatar
我爱台湾
I haven't plugged the IATS back in yet because I am still running an aftermarket intake that doesn't have a place to plug it back into. I haven't switched back to the stock intake yet. I could ground it, but would rather put everything back in place as it should be.
So I should have both the clutch and the gas pedal depressed all the way down and then try starting the car? I hate to be noonish about this but this isht is really starting to bug the hell out of me and I'm about to go to Taiwan for 2 weeks and the car will be at a parking garage. I would really like to fix it before I leave but if I can't, I'll deal with it when I return.
Forge277
Jun 13, 2016 09:26 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Marc2theMax
Sep 28, 2015 08:13 AM
