anyone replace the slave cylinder latley?
Old Dec 1, 2005 | 05:46 PM
ManualMaxima's Avatar
5th Gen till she dies!
Well I think my slave cylinder is bad cause it some free play when I move it by hand. Who gas done this? How hard is it and how long did it take? Thanks in advance
Old Dec 1, 2005 | 06:34 PM
RA030726's Avatar
I'm nutty for Nissans
its pretty simple. you should break loose the banjo bolt before you remove the SC from the tranny. then just unbolt the SC and bolt the new one on. make sure you use new copper crush rings so the hose doesnt leak. then bleed the lines. thats really the hard part, since it can take some time. its a 2 person job for sure.
Old Dec 1, 2005 | 07:04 PM
lp's Avatar
lp
I did one last weekend by myself with a one man bleeder kit. Check the slave to junction box hose carefully because they have a habit of softening up and weeping with age. Its easy to replace both at the same time.
Old Dec 1, 2005 | 07:09 PM
i am just taking a shot in the dark with this.....my clutch feels like crap. So i ordered a slave cylinder and hope this fixes the problem. if not the master cylinder is next. I just had my clutch replaced and this problem started with my old one so i know it is not the clutch.
Old Dec 1, 2005 | 07:18 PM
lp's Avatar
lp
Are you losing fluid from the system?
Old Dec 1, 2005 | 09:41 PM
MaxSpeed97's Avatar
Did your mechanic resurface the flywheel? that will make the clutch shake and chatter if he didn't.
Old Dec 2, 2005 | 06:04 AM
cardana24's Avatar
Blown
also check the hose running to the slave. I know after I replaced my clutch this started to leak, and I think it is a common problem after you replace the clutch. Do you have fluid in the resivoir (the one in the passenger side corner)? Make sure you take the cap off to check because I thought I did but it was really just a stain from the fluid where it had sat at the same level for so long.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
vingodine
45
May 21, 2016 12:46 PM
vanebecker
Aug 17, 2015 08:24 PM
