Switching a 98 max ECU to a 95 max!!
Old Dec 3, 2005 | 04:06 PM
Naija9's Avatar
Anyone know if the computer(ECU) on a 98 maxima can be switched for use on a 95 maxima? Will it cause any harm..i.e blow the circuits, blah blah....Please let me know if you have had any experience with this..
Old Dec 4, 2005 | 10:55 AM
Naija9's Avatar
bump...Guys, any ideas???
Old Dec 4, 2005 | 01:27 PM
scrhale's Avatar
I wouldn't recommend it, but if you switched a pin here and there I am sure it will work.
You may have a CEL from possible missing emissions equipment since 95's have less of them
Old Dec 5, 2005 | 01:57 PM
Naija9's Avatar
Thanks Scrhale...
Old Dec 5, 2005 | 02:46 PM
I30tMikeD's Avatar
No, the car will run fine but you will get some radom CEL's.
Old Dec 5, 2005 | 02:53 PM
tavarish's Avatar
fwd gone rwd cr00
you can use any 4th gen ecu for any year 4th gen, but you will get a CEL, the emissions equipment is different.
Old Dec 5, 2005 | 05:01 PM
L0R1DA's Avatar
What if you had a 97 Infiniti I30 and you wanted a JWT ECU? Since they do not modify the 97 ECU, but they do mod 96s and 98s, is there a particular year that I should look for that will have similar enough emissions equipment (since that seems to be the main foible with the swap) not to trigger a CEL? Thanks.
Old Dec 6, 2005 | 05:09 AM
I30tMikeD's Avatar
They don't do 98's. Just 95-96 ECU's.
I can almost promise you that you will get a CEL no matter what when running a different year ECU. I have ran several different ECU's and am currently using a 98 auto maxima ECU.
What is your concern with the CEL? For me it is just passing emmissions, so I just make sure I always have my stock computer available if I need to get tested. Besides having a CEL all the time it doesn't really matter.
QueensMAX
Sep 15, 2015 04:14 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
mix master
Sep 4, 2015 05:50 PM
