OEM Starter Question
I installed an aftermarket starter on my 95 MTX Max and it is having trouble starting. It will hesistate when tryin to start and after about 10 seconds it will start. Will replacing this with a Nissan starter fix this? Thanks for any help in advance.
Does it drag or is it not doing anything when you turn the key?
My max used to have problems when I would turn the key, it wouldnt do any thing at times. Sometime its would start and sometimes it wouldnt. If I jiggled the key, it would start no problem.
I replaced the ign. switch and have had no issues since.
http://www.courtesyparts.com/Merchant2/merchant.mvc?
I took out my aftermarket starter (it would not start at all) and brought it back to AutoZone. They tested the starter and it turned out to be bad so they gave me a new starter. I just put the new starter in and now the car won't start. It will turn over but just won't start. Does anybody have any other suggestions?
***My aftermarket starter has 10 teeth***
***My aftermarket starter has 11 teeth***
Jiggle the key?
were there any symptoms like lag or hesistations the last times you drove it?
Ignition switch replacement is easy and took me 15 minutes. There is a write up i believe in the "how to" sticky, but it might be in the "FAQ" sticky. And yes it is under the plastic thing on the steering column. all you need is a big screw driver and a little screw driver and some patience.
Thanks a lot! If anyone was looking for the write-up on the ignition switch...http://forums.maxima.org/showthread....gnition+switch
aminus21
Sep 12, 2015 04:53 PM
