Mod to change automatic shift RPM
Old 06-23-2007, 05:25 PM
  #81
96i30azn's Avatar
190hp@5600rpm here's dyno
http://www.boostaholic.com/maxima/dyno/dyno.gif
up to 6500rpm, you have very little power, why would you wanna go that high?
here's the thread i got it from
http://forums.maxima.org/showthread....hreadid=166532
96i30azn is offline
Old 06-23-2007, 05:55 PM
  #82
No more Maximas...
pmohr's Avatar
Could be useful for the future.
pmohr is offline
Old 06-23-2007, 08:00 PM
  #83
killerVQ30DE's Avatar
Well OOVI or MEVI is why you would want to go to 6500
killerVQ30DE is offline
Old 06-24-2007, 08:30 AM
  #84
Turbo 3.5
t6378tp's Avatar
Originally Posted by pmohr
I know it's been a year, but...anyone know whatever happened of this?
grey99max has a shift_fast mod which was a spin off, here's a link
http://forums.maxima.org/showthread....ght=shift_fast
t6378tp is offline
Old 06-24-2007, 08:37 AM
  #85
Bacon Lover
Tatanko's Avatar
The various shift_fast versions that some of us have worked on are essentially what this ended up being.
Tatanko is offline
Old 06-24-2007, 03:08 PM
  #86
No more Maximas...
pmohr's Avatar
I guess the shift_fast_2 with the RPM control would indeed be the distant relative of this mod here.
Just wonder whatever happened to it, after all Jime bought like $400 worth of equipment to try it out.
pmohr is offline
Old 05-07-2013, 06:23 PM
  #87
blackice0123's Avatar
The 3rd gear lag is the converter locking up, if you leave the shifter in 4th it won't do that, it only happens when you leave it in 3rd. This only applies to the A33, the A32 does not do that.
actually, I believe you're incorrect about the a32 not doing this. mine does, it's a 98se. for example, when I'm at WOT and press the O/D button on the shifter to turn overdrive OFF while in 3rd gear, the rpms drop a little bit and it holds in 3rd. and if i turn O/D back ON again before the shift point, the rpms jump a little and it shifts into 4th at 6k. and finally there is a very slight but noticable lag if i'm not WOT and use the O/D button to hold 3rd, then press O/D again to allow it to shift into 4th. basically the delay sounds like a slight rise followed by a fall into 4th. i've found this useful when driving spirited. i turn O/D off when launching and when 3rd hits I turn O/D back on giving me that little bump up in rpm. anything to get to the next gear quicker helps
blackice0123 is offline
MAXSE5SPD
09-17-2022 04:00 AM
mvm062
11-30-2020 09:00 AM
maximusrising
09-02-2015 09:55 AM
A32goldylocks
09-02-2015 06:39 AM
RealityCheck
08-05-2015 06:18 AM
Quick Reply: Mod to change automatic shift RPM
