2 screws to adjust headlights?
Old Dec 8, 2005 | 03:17 AM
Maxima 504's Avatar
I cannot remember which screw it is to adjust the headlights so that the shine more out to the sides. When I tried adjusting them I could hardly tell the difference in aim by turning the screws. Just looking for an answer as to if it is the inner screw (closest to the middle) or the outer screw (on the fender side). Thanks in advance.
Old Dec 8, 2005 | 03:21 AM
l3ftonm3's Avatar
I think its the inner screw but im not sure lol, 50/50 chance
Old Dec 8, 2005 | 03:22 AM
maxgtr2000's Avatar
KH3 by popular demand
They both work in conjuction in a way almost like a push/pull deal, but it is the inner screw that does most of it if you need to do minor adjustment..
Old Dec 8, 2005 | 03:28 AM
Maxima 504's Avatar
oh ok i got ya'll thanks. I'll just have to work on it a bit to get it adjusted how I like. I just want my hid's to be alighned properly, but it'll never happen with stock headlights..
Old Dec 8, 2005 | 04:58 AM
maxgtr2000's Avatar
well if you are just running a plug n play kit in the stock housing the light will scatter anyway, also the hid bulb may not be seated or manufactuered properly. If it is projectors the way they are mounted needs to be adjusted.
To align the headlights you need to turn the lights on facing a wall and adjust the aiming screws from there, you can either look at the beam pattern or look at the actual top of the headlight to see if the gap from the headlight housing is increasing or decreasing while you are adjusting the screw.
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Mar 29, 2016 11:08 AM
leatherneck
Sep 30, 2015 09:16 PM
Noela
Sep 26, 2015 08:22 AM
