S-Tech with AGX spring turning in the strut..
Old Dec 10, 2005 | 03:29 PM
Fr33way™'s Avatar
Wild for Width
I have the spring noise (popping) where the spring rotates inside of the strut when (steering) wheel is turning. What is the fix for this?
Old Dec 10, 2005 | 03:40 PM
MDeezy's Avatar
This noise is comming from the front? Does it occur every time you turn the wheel or occationally?
If you need me, I can be by with a spring compressor (if needed) and we can try to isolate the noise. I wasnt getting such a noise.Top three bolts were tighten down right?
Old Dec 10, 2005 | 04:32 PM
njmaxseltd's Avatar
Reseat the spring in the upper rubber perch making sure it sits evenly. Make sure the word out, stamped on the upper perch faces outwards or is in line with the struts lower mounting flange. Then regrease or replace the strut bearing.
Old Dec 10, 2005 | 04:49 PM
MDeezy's Avatar
this is the strut bearing?
Old Dec 10, 2005 | 07:38 PM
Maxtank's Avatar
I'm having the same noise, althoguh I only notice it when i'm pulling out of the garage. I expect it every time, and it happens every time. I'l take a look at it. Thanks for starting the thread, I wasn't even sure what was making the noise.
Old Dec 10, 2005 | 07:42 PM
RA030726's Avatar
I'm nutty for Nissans
definetly sounds like a bad strut bearing. it causes the upper spring perch to bind up with the mount and then the spring gets twisted.
Old Dec 10, 2005 | 08:08 PM
MaximaSE96's Avatar
Maxima Owner
i find it easier to sell the TEINS and get Eibachs.....i didint like the Teins anyway
Old Dec 10, 2005 | 08:26 PM
Fr33way™'s Avatar
Wild for Width
Never did anything like this with the D2s
Well, I guess new strut bearing it is, do I have to go through Nissan on this?
Old Dec 11, 2005 | 07:27 AM
RA030726's Avatar
nope, most auto parts stores have them.
Old Dec 11, 2005 | 08:04 AM
happyricefob's Avatar
V^___^V
http://forums.maxima.org/showthread....79#post2945079
Old Dec 16, 2005 | 02:41 PM
Fr33way™'s Avatar
Wild for Width
Just wanted to update, I did exactly ^^^ that.
The bearing was completely dry.
Old Dec 18, 2005 | 04:33 AM
dko's Avatar
dko
duck and cover
any time i've ripped apart my suspension to change something or otherwise rehauled it i've just replaced the strut bearings and mounts at the same time. it's a $150 investment that could save you $500 in labor at a shop or 3-4 hours of your own work.
regreasing the bearing isn't too hot of an idea because it usually goes bad much sooner than just replacing it. it's like a $20 part anyway. just replace it and save yourself the hassle of doing it again.
imported_Nismo_max
Feb 17, 2016 03:39 AM
rnb754
Sep 14, 2015 11:39 PM
LtLeary
Sep 14, 2015 12:33 PM
Stagnet04
Sep 13, 2015 09:32 PM
