Need Starter Help
Old Dec 12, 2005 | 04:49 PM
02RIMax's Avatar
Need Starter Help
I installed a new starter and now the car will not start. It's not the ignition switch because I already purchased a new one and installed it, the battery is fine and I even tried to jump the car. Does anyone else have any ideas what it might be. How many connections go to the starter? Thanks for any help in advance.
I connected the plug to the positive of the battery and the wire that bolts onto the solenoid but I can't find out where a think black wire goes to. Anyone know?
Old Dec 12, 2005 | 05:13 PM
njmodi's Avatar
Do I get a tax break?
Perhaps your starter is bad out of the box - did you get it bench tested at Autzone (or the like?).
Old Dec 12, 2005 | 05:18 PM
02RIMax's Avatar
Yeah it's brand new I just returned the one I had before because it was bad and had the new one tested. I looked in my engine bay near the starter and there is a thin black wire with a rectangular connector on the end that is screwed to the body of the car, the connector has one long line with three dots below it.
Old Dec 12, 2005 | 05:26 PM
MDeezy's Avatar
there is a black plug it dangles and manages to get itself lost when your installing back a new starter Look around for dangling or lose cables.
Did you reconnect everything properly?
Its possible to have gotten a bad starter out of the box. It happened to me, not too long ago.
Old Dec 12, 2005 | 09:15 PM
MaxMateo5's Avatar
if you put a new ignition switch in it is possible you could have blown that fuse..?? somebody with more experience may go against me but its right under the engine bay-worth a try because i know when a shop found my alarm to be shorting out my ignition a month ago they replaced that fuse..
Old Dec 13, 2005 | 05:20 AM
Jepht20's Avatar
Custom User Title...
sounds like you didn't reconnect that black ground wire to the bolt on the left of the starter when you were installing it. or i'm way off because i just got home from working the overnight...
Old Dec 13, 2005 | 05:29 AM
smooth_caramel's Avatar
have you tested it using the haynes manual? I just got one put on too.
Old Dec 13, 2005 | 05:30 AM
njmaxseltd's Avatar
Either it's the ground or it's the actual turn on (start) lead from your ignition switch that you forgot to connect. Aside from power, (and ground of course) you need a turn on signal for the solenoid to activate.
Old Dec 14, 2005 | 05:16 PM
02RIMax's Avatar
I have a 16 gauge wire on the frame of the car near the starter and I dont know what it goes to. The connector looks like this:
Does anybody have a clue what this is???
Old Dec 14, 2005 | 05:51 PM
NmexMAX's Avatar
dot dot dot ...
GND > you.
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
