Iv'e had it with auto trannies!!!
#81
Originally Posted by stglock
I30krab,
How much did it cost to have it upgraded? Did you remove your transmission yourself and how hard is it.
I need transmission work too but I don't know if removabl/installation is tough.
Please let me know...
thanks,
stglock
thanks,
stglock
As for R&R of the transmission, honestly, if you have to ask about the procedure, it would be best to leave it up to a professional. I would recommend to get a Factory Service Manual for your Maxima (ebay) and do some reading before attempting this.
If you want to see some pictures of when I removed and replaced my transmission, go here:
http://www.iwdwebdesign.com/maxima/tc.htm
It's roughly the same exact procedure between my car and i30krab's. It's almost the same transmission.
#82
Rebuilt tranny is in and working but, if you look under the tranny where the torque convertor bolts to the fly wheel there is a small weep hole and tranny fluid is seeping at this point. I took the car to a local competition tranny shop and they called Rob and they told me to drive on the freeway at high speeds for 50 miles and see if this is just extra fluid caught in the tq con during the reinstall!! They claim up to a cup of oil could be in there. If indeed there is a leak this local shop will pull tranny, reseal it and rob will pay. Is there ever an end to this bullsh-t??
By the way, the car is much faster at lauch.
#83
I used to drag my 91 mustang LX. (500HP) In this arena the 5 speed is quicker until you reach 400-450HP. Then the auto is quicker because there are only autos. Meaning the 5 speed can only handle up to 400-450HP. Anything higher and they break. Modified autos can handle more HP than sticks.
#84
good move bro i have a built level ten auto tranny and it is a wonderful thing. i had it for over 6 yrs before rebuilding it and it continues to amaze me. i have hit in the high 12's esy and it remains strong. by the way nice work i've been following your progress because i plan on doing the cooler set up you have howa the car running?
#85
Originally Posted by HarrisH
Please research before you post crap like this. YOU CAN BUILD an auto to be MUCH faster than a manual. Supras that run 9s and 10s many of them ARE AUTOS. A lot of Nascars are autos! There is not THAT much of a weight difference. The only thing your 5th gear is good for is for conserving gas THAT IS IT nothing else. IT IS NOT STRONGER NOR A LOT MORE RELIABLE. 5 speed trans go bad ALL THE TIME. You can NEVER build a 5 speed to half as strong as an auto. Yes my 2nd shifts so fast that it lifts the wheels off the ground but that's because I have an upgraded racing VB with a built transmission.
#87
Originally Posted by maxS
bunch of B.S. get real
in fact i havent lost a race to a five speed yet .
#90
#92
Well this is fact in the 5.0 arena. I have raced this arena for 10 years and recently sold my 5.0. I doubt that any five speed could handle that type of HP.
There is not a manf that makes a solid 5 speed to handle obove 400HP for 5.0's. Ask anyone who races there 5.0 and they will tell you this.
Also, if you have a blow off valve, that helps you stay in boost (turbo only).
BTW i ran a SC on my 5.0 w/auto trans. Sticks are quicker with the right driver under 400 HP, been proven at the track. U take an identical car, one with built auto and one with stick and someone who can shift it. The stick will own.
#93
Originally Posted by C MAX
he speaks the truth as far as overall hp race cars they are all automatics. my boy vinny ten has a 7.6 second auto supra. im auto also and you can ask any ny member in this forum am i a push over because im auto, i think not.
#94
Originally Posted by vsamoylov
still b.s
#96
well then obviously your an idiot. what does your five speed do at the track 14.8, when you say something intelligent then i'll respond in a better manner.
#98
Back to the garage
Rebuilt tranny is in and working but if you look under the tranny where the torque convertor bolts to the fly wheel there is a small weep hole and tranny fluid is seeping at this point. I took the car to a local competition tranny shop and they called Rob and they told me to drive on the freeway at high speeds for 50 miles and see if this is just extra fluid caught in the tq con during the reinstall!! They claim up to a cup of oil could be in there. If indeed there is a leak this local shop will pull tranny, reseal it and rob will pay. Is there ever an end to this bullsh-t??
By the way, the car is much faster at launch
Like I said before, no end to this sh-t!
The tranny is still leaking and it has to come out.
#99
line up next to me and i will blow you away. and looks who is a idiot. i dont have a 5 speed but a 6 speed. maybe you should g o into the all motor forum for once and read up.
#101
not street tires
and i never run with out my dr's street legal . p.s i wish i had a six speed but i dont does that make you feel better,lol.
#104
OK.... since my post is still < 15, I cannot start a new thread.... hopefully, I could get answer.
My '96 Max auto trans starts to slip from 2 to 3 if I pull quite hard. So, what do you think?
Should I let it go worse and replace later?
or
Should I get it fixed now before getting worse? If so, how much approximately (so I know if my regular shop gives me good deal or not )? Is it cheaper to get a rebuilt one?
or
Should I start thinking about manual swap?
Thanks a bunch before and after.
or
or
#106
...the whole point is auto is faster in the long run with high hp period...
#107
Originally Posted by i30ds
How do you figure that?!? A manual will ALWAYS put down more hp than a auto counterpart due to less drive train loss. Are you just talking about the ability of an auto to bang a gear quicker?
i like stick better too but this is just facts.
#108
:just look at the fastest cars out there are auto or hertz shifter no 5 or 6 speeds, and yes because they shift quicker
i like stick better too but this is just facts.[/QUOTE]
Just want to thank you guys for hijacking my thread!!
#109
: : :.[/QUOTE]
Just think of it as a free bump to the top... enjoy the lime light!
fx4five
10-18-2015 06:57 PM
fx4five
10-01-2015 04:58 AM
