heat only when accelerating // ice cold when idling
Old Dec 17, 2005 | 10:13 PM
kbmaxima's Avatar
i'm trying to figure out (googling) what this could be. Seems to be a simple coolant flush would do the trick, but i'm thinking it could be the thermostat. but then if the thermostat is stuck in either position, shouldn't the car give off no heat and car overheating/not warming up?
Old Dec 17, 2005 | 10:19 PM
alpimax99's Avatar
get the car warm and squeeze the radiator hoses are they swooshy?
Old Dec 17, 2005 | 11:47 PM
the_3d_man's Avatar
aren't the gates that control airflow driven by engine vacuum?
I don't know alot about it for the maximas but I have heard of older cars having the vacuum seals in the ventelation system wearing out causing things like hot/cold air flow becoming messed up and lower/upper/defrost vents blowing when they shouldn't be.
Can't offer anything other than that. maybe someone can give more info
Old Dec 18, 2005 | 06:13 AM
njmaxseltd's Avatar
Have you checked the coolant level lately? What you describe sounds like your low on coolant. A lazy thermostat will make the car run cold. Is the temp gauge stable in the normal (mid) range? Do you have auto climate control or manual?
The airflow control on our cars is driven by electric actuator motors, not vacuum.
Old Dec 18, 2005 | 08:16 AM
DoNcHoYaX1's Avatar
just add coolant your probably out of it dont add it to the bucket thing add it to the radiator.
Old Dec 18, 2005 | 04:33 PM
Gold5sd96maxima's Avatar
prob. the thermostat go to auto zone it comes w/ the housing and Gasket...
Old Dec 18, 2005 | 05:50 PM
alpimax99's Avatar
I would do an oem thermostat before i'll do one through autozone. an autozone is what i have on my car and now my fans are always running. with an oem one i never had that problem. so now i'm gonna put an oem one back in and see what happens
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
D Mason
Jun 21, 2016 04:43 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
