Steering wheel vibrates
Old Dec 20, 2005 | 04:22 PM
LeVeL's Avatar
At about 60-70 (and above) the steering wheels starts to vibrate. I am sure that small vibrations are nothing to be worried about but mine vibrates kind of a lot. What could this be?
Old Dec 20, 2005 | 04:23 PM
FunLovinMaxima's Avatar
From: a charming town in Connecticut first settled in the 1600s
start with the simple stuff: check tire pressure and get tires balanced.
Old Dec 20, 2005 | 04:25 PM
a_prince1's Avatar
alignment too
Old Dec 20, 2005 | 04:27 PM
iceman82's Avatar
I had the same problem and my tires were warped check that as well
Old Dec 20, 2005 | 04:34 PM
LeVeL's Avatar
I pumped the tires a few weeks ago and they are still good (visually). Can potholes screw up my allignment? Cause I did hit a big one yesterday...
Old Dec 20, 2005 | 05:11 PM
MDeezy's Avatar
Pot wholes possibly if it slightly bends certain parts.
If you havent gotten an alignment in a while, then it wouldnt be a bad investment.
Old Dec 20, 2005 | 05:13 PM
Supermax95's Avatar
do you have aftermarket rims? If so, it's possible that you need hubcentrick(sp?) rings....
Old Dec 20, 2005 | 05:21 PM
wmoates2's Avatar
where would one get these hub rings that you speak of?
Old Dec 20, 2005 | 05:27 PM
devilz05's Avatar
Shift_3.0
Do the vibrations start to go away at 80+?
You have aftermarket rims, right? Could be that one of the weights on the wheels came off. Aftermarket rims need special weights and just taking it to autozone usually doesnt cut it. Check to see if all the weights are in place, I know with my old rims the weights were on the understide of the rim and detached at times.
Old Dec 20, 2005 | 05:31 PM
descent's Avatar
check your lugs!!! i put on 350z rims and 1 lock nut per tire. one day i notice problems and take it to the garage. every other nut was lose as if someone tried to steal the stuff and then realized i had lock lugs. my wheel vibrated, i heard knocking noises and a lot of other stuff.
Old Dec 20, 2005 | 06:43 PM
darklegend06's Avatar
I had the same problem with my car. I looked into it and found out that my brake calipers were loose and of course that made my pads deform a little, causing it to viberate at high speed. So i cleaned it and sanded down my pads until it was surfaced and clean. since then I have no problems. I also had the problem when I got ice on top of my transverse link unit after hitting a snow pile. That totally made my car shake but I melted it down so it was ok.
Old Dec 20, 2005 | 07:22 PM
Supermax95's Avatar
If you get your rims from a tireshop they usually come with the rims......but you can get them from pretty much any shop that sells aftermarket rims.
Old Dec 20, 2005 | 08:28 PM
Maximasaresweet's Avatar
this could be unbalanced rims, bad tires, or bad front brakes......let me know how thing come out
Old Dec 21, 2005 | 03:08 PM
LeVeL's Avatar
Thanks guys. My rims are stock though.
devilz05 - i havent gone above 80... a bit scary when the steering wheel is going crazy. At 80 though its still the same...
darklegend06 - my dad suggested I do the same lol.
I'll try an allignment, check the tire pressure again, and tighten my nuts (lug nuts). If that doesnt work, mechanic's it is. Thanks all.
Old Dec 27, 2005 | 01:19 PM
maxsthebest's Avatar
I would start getting used to it. I have had vibration on my Maxima since I have owned it. Alignments don't make it go away. New tires don't make it go away. Balancing sometimes improves it a bit but then it comes back again. The only thing I haven't done is to replace the LCA and inner tie rods, as suggested on the Org by one of the members who stated that this cured the steering wheel shaking.
This, unfortunately, is a common problem with 97 Maximas. Many mechanics are aware of this condition.
Other than that, I love my Maxima and it's the best car I have ever owned. The car is a "beast" and I love driving her!!!!
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
