Both fans not working...
Old Dec 20, 2005 | 09:50 PM
Maximized Jiggs's Avatar
So I thought my heat wasnt working as it use to so I put on the auto climate control on max fan speed and on high. It blew air but not as hot and not as much in volume as it once did. I opened the hood and saw that both of the fans werent on, I checked a couple of times to see if that changed but it never did. The car doesnt seem to over heat as the temp gauge stays right in the middle.
Other than fuses, what else should I look it to see why both of the fans arent working? Could it be a bad radiator as well? What do you guys suggest?
Old Dec 20, 2005 | 09:55 PM
iceman82's Avatar
check you wiring maby a loose connector
Old Dec 21, 2005 | 04:44 AM
njmaxseltd's Avatar
Auto climate control runs the comperssor when it's above 32F.
When it's below freezing, no compressor & no fans.
If your heat isn't blowing hot and your temp gauge never reaches the normal mid point, chances are you need a new thermostat.
Old Dec 21, 2005 | 07:30 AM
It was about 40 degrees last night so not sure if that would trigger the fans or not. So no matter what it wouldnt put the fans on below 32F huh? Just wondering how else I can test them.
My temp gauge is fine and it warms up fine as well so I dont think my thermostat is bad. If I remember correctly, I did change that last year...but I could be wrong. Any one know if air in the cooling system could also affect the heat settings? I hope its not my radiator then as to why my heat isint as hot as it use to.
Old Dec 21, 2005 | 07:31 AM
I thought I did hear the compressor, maybe thats what a heater core is.
Old Dec 21, 2005 | 12:09 PM
ManualMaxima's Avatar
5th Gen till she dies!
reley maybe?????
Miket2006
Mar 1, 2021 03:55 AM
Smackasmith
Feb 1, 2016 12:40 AM
RWCreative
Sep 21, 2015 11:01 AM
asianstyle
Sep 10, 2015 11:30 AM
