newfound questions about my max
Old Dec 21, 2005 | 12:15 AM
sachmo's Avatar
I got stuck in the snow the other day and i noticed that only one of my wheels was turning and the other one was going. If i eased in on the clutch both wheels would spin. Does this mean that i have a limited slip diff??? Also my abs light came on which i had never seen before. I Always thought that i did not have ABS on my car either. anyone know if my assumptions are right???
Old Dec 21, 2005 | 12:28 AM
the_3d_man's Avatar
actually... it's the contrary... if you had limited slip one wheel would not be spinning and the other stopped. Limited slip differential will try to lock the two sides together when one wheel starts to spin faster than the other, which would have helped you get out easier. I can't tell you if your car has ABS you should know this. It might help if you told people what year and trim you have. I am guessing that sense the wheel obviously lost traction and was spinning freely and that you got an ABS light (which is supposed to come on to tell you that ABS sensor has detected a loss of traction) that you have ABS
Old Dec 21, 2005 | 08:50 AM
MorpheusZero's Avatar
Go to a non-icy parking lot and stomp on the brakes. If your wheel(s) lock, you do not have ABS. If you feel a sort of pulsing sensation in your pedal and the car comes to a quick stop, you do.
Likewise, in the same parking lot, turn the wheel all the way to the right or left and nail it. If one wheel spins and all you get is a bunch of smoke, then you've got an open diff. If both wheels spin, your car kinda goes straight but takes off quickly you have an LSD.
From your description: open diff, ABS.
Old Dec 21, 2005 | 08:54 AM
NmexMAX's Avatar
dot dot dot ...
Easier on an icy parking lot to verify.. All taht pulsing.
Read stickys, check VIN to see if you have LSD.
Old Dec 21, 2005 | 11:36 AM
ManualMaxima's Avatar
5th Gen till she dies!
if you have a abs light in your car you have it, have you never noticed it when you put the can in ACC before starting it the abs light comes one?
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
