to those who have taken out the clock/vent assembly
Old Dec 21, 2005 | 10:13 AM
FormorAccordMan's Avatar
After installling a stereo in my car, the clock/vent piece never sat perfectly flush. I have a few milimeters of space between the main panel and the vent/clock piece. When putting the assembly back in, i have simply pushed it straight in and it locks into place. Is there a specific way to get it back in to eliminate the gap? It seems that Since I devirginized the factory seal that i may have the gap forever, if thats the case, its no big deal, but is there a way to eliminate it? Thanks
Old Dec 21, 2005 | 10:16 AM
Nismo's Avatar
On the bottom of the piece there are 2 tabs that lock into the frame of the dash, check those and see if they are bent inward. I had to rebend mine back out so that the tabs would lock back into the hole.
Old Dec 21, 2005 | 10:28 AM
sook's Avatar
tabs on the bottom are messed up, youll have to pull the whole thing out and try again.
i just ignore my gap, it was too much of a pita to get it out the first time
Old Dec 21, 2005 | 11:14 AM
4x4Max's Avatar
dude it takes like 30 seconds to take apart the console/dash peices, including the screws, it cant be a PITA
Old Dec 21, 2005 | 11:15 AM
Fr33way™'s Avatar
Wild for Width
It most def. your tabs, be careful with the AC vents while you are in there.
Old Dec 21, 2005 | 11:16 AM
Fr33way™'s Avatar
Wild for Width
It's a PITA because it is all thin plastic and that can be nerveracking.
Old Dec 21, 2005 | 11:32 AM
86maxima96's Avatar
I Broke OT
agreed. i hate messing around with my dash more than i have to. removing that panel by the driver's knees once for a gauge bezel install was bad enough, but then again for gauge rings!?!? let's just say it's seen better days. those clips are indeed a PITA
EDIT: and yes, i removed my clock assembly and it does stick out just a mm or two.
Old Dec 21, 2005 | 02:07 PM
mjb95maxse's Avatar
i broke 1 of mine really easy to do be careful
James92SE
142
Jan 2, 2024 09:23 AM
atriuum
Sep 28, 2015 01:19 PM
Noela
Sep 26, 2015 08:22 AM
ajahearn
Sep 19, 2015 03:03 PM
MannyMonroe
Sep 17, 2015 02:34 PM
