RPM settings
Old Dec 24, 2005 | 01:58 PM
jian622's Avatar
RPM settings
what is the normal RPM speed when its in D mode? mine is 500-600
what is the normal RP< speed when its in R mode? mine is about 500-600
what is the normal RPM speed when its in N mode? mine is about 650-600
what is the normal RPM speedn when its in P mode? mine is at 700-800
its all like this when its warm ................the car seems more smooth when its in N mode..........is it normal?
Old Dec 24, 2005 | 02:11 PM
NmexMAX's Avatar
dot dot dot ...
ALl looks well.
Old Dec 24, 2005 | 02:23 PM
surfman21's Avatar
pretty normal to me...sometimes when you have your A/C on or Heater or even your system, your rpms will be slightly higher to compensate for the lost power there.
Old Dec 24, 2005 | 07:48 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
looks good to me too mine sits at about 650-675 in drive when warm
Old Dec 24, 2005 | 09:08 PM
Mxrider52's Avatar
I support for what?
The car runs better in neutral because your not putting any pressure onto the motor
Old Dec 24, 2005 | 09:58 PM
tikiboom's Avatar
I need an intervention
those are the same rpm ranges for me as well, although i noticed that if you look really close the tach is actually moving like a fraction of a fraction of an inch up and down. Dunno if thats normal but i just thought it interesting to point out.
Old Dec 25, 2005 | 04:18 PM
jian622's Avatar
the car seems to be somewhat shakey while in D mode......i have cleaned the Intake and its still doing the same......what could be the casue?
Old Dec 25, 2005 | 04:56 PM
pmohr's Avatar
No more Maximas...
Have you pulled codes?
In response to the answer I anticipate, check the stickies, that's how you pull them.
shilov
Feb 19, 2024 09:40 PM
mvm062
Nov 30, 2020 09:00 AM
JoshG
51
Sep 21, 2015 10:41 PM
slowlifer
Sep 8, 2015 05:53 AM
dcardello
Sep 3, 2015 11:44 PM
