clock goes out
clock goes out
my clock just cuts out..i have an aftermarket deck in my car, and the dimmer wire was connected improperly when it was installed by the eclipse dealer...i checked the fuses, and theyre fine, has anyone else had similiar problems?
nissan needs to get a new supplier for the clocks. both my 94 & 97 clocks had to be re-soldered. usually its the big resistor. when you look at where the solder goes around the leg of the resistor (or anything that is soldered) the solder should look like part of the leg, you should not be able to see a "ring" around the component leg. using a 10 power magnifier helps a lot.
Same thing with mine. has been this way for a year+. Its not a short, shorts blow fuses, ive taken it apart, and all the connections LOOKED good, i didnt test anything though. Ive just learned to use my phone. notice that almost all flip phones fit in the door handle
I have the same problem. Sometimes it will work, sometimes it won't. If it is working and you tap on it, it will go off. I haven't gotten around to taking it out and trying to fix it yet. My phone barely fits in the door handle. If you know anything about phones it is a Sanyo MM-7400 from Sprint, it has the rubber around the bottom portion so it makes it a little wider. It sticks out but it stays in there. Good for easy reach when using a headset on long drives.
shilov
Feb 19, 2024 09:40 PM
t6378tp
Sep 29, 2018 04:27 PM
Matt93SE
Apr 8, 2018 09:23 AM
vingodine
45
May 21, 2016 12:46 PM
viperboy
Sep 27, 2015 07:05 PM
