Bulb in seat heater switches? 95-99
Old Dec 26, 2005 | 11:54 AM
Tim96I30t's Avatar
Does anyone know the size of the bulbs in the heated seat switches? I will take a close up pic and post it. Thanks everyone
Old Dec 27, 2005 | 09:09 AM
Tim96I30t's Avatar
nobody knows the size, any help
Old Dec 27, 2005 | 11:42 AM
RA030726's Avatar
I'm nutty for Nissans
radio shack may have something that fits. i replaced mine with leds. its to simple.
Old Dec 27, 2005 | 12:05 PM
Tim96I30t's Avatar
I did that, they did not work, put both wires on the copper bars, one on each.
Did you use a resistor? Or just LEDs? Did you reuse the holder for the bulb?
Old Dec 27, 2005 | 12:42 PM
rdjay's Avatar
I found what I think will work at bulbman.com. I ordered three of the #8111 incandescant bulbs but haven't got them yet. They are only $1.24 each so I figure it's worth a try.
Old Dec 27, 2005 | 01:56 PM
RA030726's Avatar
yes you need a resistor. watch for polarity also. i think i soldered directy to the copper.
Old Dec 27, 2005 | 02:37 PM
dariod's Avatar
Does anyone know what type of bulbs is on the dash (rear defroster button, hazzard button).
Old Dec 27, 2005 | 07:20 PM
Tim96I30t's Avatar
thanks
I am going to do this to my old ones with green leds, what size resistor did you use?
Old Dec 27, 2005 | 07:48 PM
RA030726's Avatar
good question. iirc 470 ohm but im not 100% sure. they came with the leds. you may need different ones for the leds you use.
Old Dec 27, 2005 | 08:13 PM
DcMaN's Avatar
your switch could be bad.... Ive seen a number of bad heated seat switches. Check the fuse as well.
Old Dec 28, 2005 | 09:52 AM
Tim96I30t's Avatar
I think I would know if they were bad, it been 30 here average, heaters work fine top and bottom just the bulbs burned out. I want to take pics when I do mine for others in the how to.
Old Dec 28, 2005 | 10:09 AM
MAXTIZZLE's Avatar
i was trying to replace the bulb in the switch last night, but i wasnt sure how to get to the bulb. where does the switch come apart?
Old Dec 28, 2005 | 11:14 AM
MAXTIZZLE's Avatar
Anyone Happen To Have Pics
Old Dec 28, 2005 | 02:03 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i thought i saw a write up on this
Old Dec 29, 2005 | 04:21 AM
MAXTIZZLE's Avatar
i just looked through the how to's and didnt see anything.
anyone?
Old Dec 29, 2005 | 10:24 AM
Tim96I30t's Avatar
Flat head, small
Take out the blue part on driver and black for passenger, you will see a slot where it locks in on both sides put flathead in and pull a little bit, do to other side, it should pull out then. Only a little on each side at first, pop both sides first w/ flathead, then it will pull out. Don't worry if you break them, switch will still hold tight, just be careful, its time consuming.
Old Dec 29, 2005 | 10:39 AM
MAXRB8's Avatar
You are correct 470ohm 1/2watt will do, I changed all my lights to LED except the heated seat switch, PIA to convert now my dam light has burnt out also but the dealer doesn't sell the bulb only!!??? Just the complete switch, so if anyone can find aftermarket bulbs let us know!
Old Dec 29, 2005 | 12:16 PM
FormorAccordMan's Avatar
you have to pry it apart
Old Dec 30, 2005 | 09:43 PM
RA030726's Avatar
try these http://www.radioshack.com/product/in...tId=2103780&cp
Derrick2k2SE
Nov 19, 2015 10:14 PM
meccanj98
Sep 17, 2015 08:28 AM
BrandonCause
Sep 14, 2015 10:41 PM
Maxie40
Sep 14, 2015 11:28 AM
minsbang
Sep 11, 2015 08:48 PM
