Helios HID Install Question
OK so I just got my Helios install kit today...havent gotten a chance to piece it all together on the max.
My question is that there are three ballast connectors, what does the third one connect to?
![](http://memimage.cardomain.net/member_images/5/web/413000-413999/413443_175_full.jpg)
Originally Posted by PBX
Yah its the 9004 plugs...so do those plug right into the harness? There are three tho?
![](http://www.albaniansausage.com/pix/maxima/3.JPG)
OK so those grey plugs are both loose...they dont have anything that they plug into.
Heres any overview...two of those red plugs are attached and one is free. The one thats is free seems to be the one that needs to connect to the headlamp power supply if im reading the diagram right.
![](http://www.albaniansausage.com/pix/maxima/PICT04081.JPG)
Originally Posted by Tatanko
"both"...there's 2? Is there anything plugged into your stock 9004 headlight harnesses at the moment?
OK so heres the full setup all hooked up. The two things that I've circled are things that I dont know where to connect...
Also the two grey plugs that are connect to the blue harness...do those connect to anything?
men its very easy...look the picture again, one of the socket that is attached to the oem connector if you see in the pic is alone, and also the other "red" conector is attached to the other connector why? cause we just need one power supply cause the main harness has the power to the 2 ballast.
The pic on your reply #28, you made a circle, thats the connector that will be alone(no connection), you just need to connect the bulbs and to the oem socket to help the bulb to change the high and low beam option.
Also on the same picture, look upper side and you will see the relay and the Red connector (on the left)that you made a sing on the reply 29, why you dont see it alone, cause is connected.
Awesome so everything is all hooked up and they power on. But now my high beam light on the dash is always on.
Also when switching between high beam and low beam it seems like its reversed. When I put on the high beams the lights point down to the road.
When putting on the low beam they point up and cover more space. Any ideas. Thanks!
