i think my front ksports r shot.....
Old Dec 29, 2005 | 07:11 PM
VIP Maxima
i just want to be sure. how can i tell? i hear all kinds of cracking noises when i turn the wheel (specially to the left) when im rolling at 5mph or less and when the car is sittin and i just turn the wheel. when im rolling, i still hear it sometimes. there is also this tickin noise thats always there when i get on the gas at lower speeds. a lot of times when i come to a stop, out of nowhere i also hear this crackin noise which i can feel in the pedal. when i hit big bumps, i also hear this CLUNK noise from the suspension. i hear the same noise when i take sharp turns in the twisties. ride quality seems to be the same. i havent had the time to take things apart and examine them. could it be my axle's or ksport reliabilty has been proven? tires r tucked in upfront and axles barely have 6k on them
Old Dec 29, 2005 | 08:11 PM
jaemax's Avatar
im not so sure but I would check for leaks if you think they are blown. How long have you had them on the car for already?
Old Dec 29, 2005 | 08:20 PM
Luigi38's Avatar
If the ride is the same, the shocks are probably not blown. I have Ksports on my car and in one of them the plastic piece was not in the right position and was making a clanking noise. You should take things apart and check your installation.
Old Dec 29, 2005 | 08:37 PM
Black Maxima
UUUUMMM DUDE Your Max is low.
Old Dec 29, 2005 | 08:59 PM
Maximus_95's Avatar
he's got 19's, it makes the car look extra low.
Man , i want 19's!
Old Dec 29, 2005 | 09:21 PM
Black Maxima
I have 17's...
Old Dec 29, 2005 | 09:23 PM
Nealoc187's Avatar
SLOW
Sounds a lot more like the strut tower bearings than blown coilovers...
Old Dec 29, 2005 | 11:59 PM
Fr33way™'s Avatar
Wild for Width
Have you checked where the top hat nut is? That was a source of noise for my D2's.
Old Dec 30, 2005 | 12:09 AM
ManualMaxima's Avatar
5th Gen till she dies!
i have that same clicking noise......i am going to tighten everything up tomarrow. also is there anyway you can post a pic of inside you wheel when the car is sitting on the ground? mine is just like yours tucking in front on 19's and i have the bottom mounts at the very bottom of the strut, and it slammed my car. my rack and pinion looks like it is being bent or something....
Old Jan 1, 2006 | 10:00 PM
DR-Max's Avatar
Like I told VIP.......those angles are bad on the rack and pinion and also on the axles. The rack and pinion can handle some flexing but not extreme drops. It won't be long and you will be replacing those things. Rack and pinions are at least $700 plus labor. Labor will be astronomical.
Old Jan 2, 2006 | 06:58 AM
chillin014's Avatar
i would check the collars and tighten them. mine came completely looks after like 2 weeks of driving and cause creaking noises at low speeds while turning.
the clunking is somethign to do with a bolt sliding.
check this ksport thread in the general maxima forums it describes nosies like you say.
http://forums.maxima.org/showthread.php?t=406790
check the first post.
wyobbagy
Jan 3, 2023 12:03 PM
BkGreen97
Apr 2, 2016 05:47 AM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
