No gains from Y-pipe?
Old 12-30-2005 | 04:08 PM
KCMaxima98's Avatar
I just had my stainless budget y pipe installed about three days ago. I reset the ecu and have no codes. It seems to run the same except a little bit louder now. When I press the gas more than half way I get this annoying buzzing sound almost like an exhaust leak. I inspected the install and everything looks tight. Is this buzzing sound normal or should I suspect a leak somewhere? Shouldn't I be noticing some extra power or is it too subtle to tell?
Old 12-30-2005 | 04:13 PM
Mxrider52's Avatar
I support for what?
Power should be instant after install the sound your talking about sounds like bees in the can sound double check and see if everything tight
Old 12-30-2005 | 04:14 PM
mtnbikeair's Avatar
If someone else installed your y-pipe get them to check it to make sure it isnt leaking...
But as for the power... you can only let out as much air as you bring in, so if your intake is still restricting then your exhaust upgrades wont be as noticed.
Old 12-30-2005 | 05:01 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
if you wanna feel anything do the y pipe and true CAI at the same time.
Old 12-30-2005 | 05:06 PM
Tatanko's Avatar
Bacon Lover
I was always under the impression that the y-pipe would be noticeable even if you were otherwise stock...
Old 12-30-2005 | 05:09 PM
YoU CaNt SeE mE
havent done it to my vq yet but my VE was noticable after both were done..
Old 12-30-2005 | 05:17 PM
Kevlo911's Avatar
Kevlo for President
You should notice it with stock intake. You should feel faster above 4500 rpms.
Old 12-30-2005 | 05:26 PM
keb1209's Avatar
So I won't feel any gains with just the Y??
Old 12-30-2005 | 05:29 PM
NmexMAX's Avatar
dot dot dot ...
Nope, y-pipes are
Old 12-30-2005 | 05:52 PM
Tatanko's Avatar
Bacon Lover
Originally Posted by NmexMAX
Nope, y-pipes are
You're not supposed to tell people the secret
Now the whole y-pipe market is going to crash...
Old 12-30-2005 | 05:59 PM
KINGMAX's Avatar
I got some buzzing and rattling from the flex section in my budget y-pipe. Me and the people riding in my car noticed a difference
Old 12-30-2005 | 06:08 PM
1996blackmax's Avatar
It is not necessary to do both to feel the gains. They are not huge, but should be noiticeable.
Old 12-30-2005 | 06:12 PM
KCMaxima98's Avatar
Okay maybe so but at the same time it feels maybe a little more sluggish in the 2K-3500 rpm range. I saw the dyno graph at motorvate.ca on the budget y-pipe but I'm thinking that maybe 97-99 or 98-99's are different in some way. That guy's 96 got 17+ whp, I would think that would be very noticeable.
And the buzzing sound is unmistakeable. I don't know if you call it bees in a can or what but it actually sounds like a rattle on a rattlesnake. It is quiet as stock as long as you keep off the gas pedal but when you hit it it gets really noticeable. It isn't too annoying and I expected there to be a different sound after I put it on but I was wondering if it was normal or not. Wouldn't an exhaust leak make noise no matter how hard you are pressing on the throttle? Like I said, I inspected it and everything looks screwed down tight.
Old 12-30-2005 | 06:21 PM
tavarish's Avatar
fwd gone rwd cr00
Your hp-sensing sensor is broken.
the buzzing is most likely coming from the flex section, or something's not bolted down as tightly as it should be. Y-pipes are the best bang for your buck mod on a Maxima, and no, the 98-99 weren't made any differently power-wise from the 95-96..
That sounds like bees in the can. I ended up wrapping my y-pipe with headerwrap and it made a significant improvement on the noise.
Old 12-30-2005 | 06:26 PM
Mxrider52's Avatar
I support for what?
Just add a popcharger and you should feel the difference there was a review and a dyno on one running just a popcharger with a y pipe getting a gain of 31 HP at 6,000 - 6,200 RPM
Red line is stock with a stillen cone intake and blue line with stillen cone intake and budget y pipe
Your only gonna notice gains above 3500
Old 12-30-2005 | 06:29 PM
buttonhook's Avatar
Where is it posted??
Old 12-30-2005 | 06:30 PM
Dave H.'s Avatar
I installed my budget y-pipe on my completely stock engine last monday and i noticed the gains immediately. It is most noticeable in higher rpm's as said previously. There is a little more growl upon partial throttle but WOT is louder than stock. I too have a very slight (buzzing?) sound, especially when i accelerate heavily. I will check the bolts to make sure they are tight.
So i don't know how you wouldn't feel a difference...
You said you inspected it and it "looks" tight, but did you actually get the wrench on there and try to tighten it more? Just a thought...good luck.
Old 12-30-2005 | 06:32 PM
KCMaxima98's Avatar
bees in a can huh? All well. I'll deal with it. It does seem to have a little more pull in the upper rpm range maybe. It is hard to tell. Maybe I should just go ahead and get a jwt popcharger or something to go with it. I was trying to keep it quiet but I'll bet a cone filter would drown out the bees I'm not sure where I would put the air temp. sensor thats in the airbox or the "boost" lol sensor that is mounted in the snorkel on the intake.
Old 12-30-2005 | 06:35 PM
KCMaxima98's Avatar
The shop that did it used air-tools. I didn't try to wrench it but I shook it and the pipe didn't move. The shop put new nuts/bolts on there too. I didn't install it myself because of the cat bolts. The shop had to torch them off.
Old 12-30-2005 | 06:43 PM
Dave H.'s Avatar
: Maybe I should just go ahead and get a jwt popcharger or something to go with it. I was trying to keep it quiet but I'll bet a cone filter would drown out the bees
What about a k&n drop in panel filter. That is what i plan on doing...It will still be quiet...but with a little growl...and possibly more power....I say possibly due to the big debate about intakes...
anyone else have this setup...budget y with k&n panel filter...can you confirm what it sounds like, more power?????
Old 12-30-2005 | 06:59 PM
Mxrider52's Avatar
I support for what?
http://www.motorvate.ca/mvp.php/504
Old 12-30-2005 | 07:29 PM
p00tan6's Avatar
hey kcmaxima98, where did you get the y pipe installed and how much was it?
Old 12-30-2005 | 07:41 PM
BigLou93SE's Avatar
The gains from a y pipe are not dependant on an aftermarket intake. I don't believe that for a second. I don't know why you didn't feel a difference after installing the y pipe, but I am almost certain that if you installed a popcharger you would feel no more power and just noise. You probably have just been imagining the gains from the y, and it doesn't meet your expectations in real life.
Old 12-30-2005 | 07:45 PM
NmexMAX's Avatar
dot dot dot ...
Another y-pipe thread
It's a sekrAt
Old 12-30-2005 | 08:02 PM
Rotncarcas's Avatar
I'm happy with my K&N, the y and b just seem too much hassle for gains that some people say arent even noticeable...
Old 12-30-2005 | 08:34 PM
Dave H.'s Avatar
so you have the k&n panel filter, y pipe, and the b pipe, with stock muffler? Or do you only have the k&n panel filter?
Either way...
How does it sound? Did you feel the gains? Do you have any mysterious buzzing sounds?
NmexMAX's Avatar
dot dot dot ...
That's why I said they're s00pid
Old 12-30-2005 | 09:01 PM
Puppetmaster's Avatar
Put your stock y-pipe back on and you'll be able to tell the difference.
Old 12-30-2005 | 09:10 PM
buttonhook's Avatar
Thank you!!
Old 12-30-2005 | 09:43 PM
themills's Avatar
Old 12-30-2005 | 10:19 PM
konak85's Avatar
Hey guys, i'm getting a buzzing sound upon light acceleration under 2,000rpm. I can think of two things:
1. I did not install the hanger where the Y and cat meet.
2. One of the bolts connecting to one of the headers left some metal debris in the thread hole when i took out the stock Y and the bolt won't sit very good.
Whats the proper or best way to clean out the thread?
Someone give me some suggestions, i wanna get rid of this dreaded sound.
thanx
Old 12-30-2005 | 10:27 PM
Mxrider52's Avatar
I support for what?
Brake cleaner
Old 12-31-2005 | 12:37 AM
maximaman10's Avatar
I did. Noticed drop in gas milage too.
Old 12-31-2005 | 06:11 AM
Tatanko's Avatar
Bacon Lover
Most people report a gain
It probably helped, and you just floor it too much now...
Old 12-31-2005 | 06:12 AM
devilz05's Avatar
Shift_3.0
What I learned from my previous car is that the only worthy engine mods are swaps, turbo/super, and the additional nitrous if your heart really desires it.
Thats my philosophy, but to each his own
Old 12-31-2005 | 07:51 AM
nismology's Avatar
What's funny is that most people that buy all the bolt-ons and such look back and wish they would've just saved all that money and put it toward a real power mod. It's just that new modders are too cheap to do it any differently. Interesting indeed...
Old 12-31-2005 | 08:18 AM
devilz05's Avatar
Shift_3.0
You are precisely correct. The only reason I would buy a y-pipe, headers, intake, cat-back is if I knew that I was boosting in the future and only then would adding these breathe free mods be worth the money.
If you think about how much money you spent on the little things, installation included, you would realize that you could have just saved up and bought yourself a nice used kit. Nothing makes me more than the sound of a sequential blow off valve in my car....one day....
Old 12-31-2005 | 02:05 PM
KCMaxima98's Avatar
I would never boost this car. I'm not mechanically inclined enough to troubleshoot all the problems that would come with it. This is my daily driver and I just wanted a y-pipe and possibly a cone filter (without getting rid of the stock piping and resonator) just for a little extra power. Maybe it isn't worth it but I figured it might get me close to 20 whp and that would be noticeable. I think I notice a little extra power with just the y-pipe but no where close to 15-20 hp like they claim. I doubt the intake is going to make that much of a difference.
Most of what I have spent on this car is trying to upgrade my once bare bones GXE. I added SE five star wheels, sound system, spoiler, red/clears, DC clears on the front ect. I'm actually about done with this car. I'm going to tint the windows and add factory fog lights and maybe a popcharger but that's it. What's funny is that I have spent more on replacing the manual transmission and alternator than all of the other stuff combined
Old 12-31-2005 | 02:09 PM
tedo007's Avatar
faster than you think
i had a same experience about exhaust leak but guy left the O2 sensor lil loose and bolts where your cats and ypipe goes together it was lil loose. i took it back and he made them tighter noise is gone so that might me your problem go tight them more
Quick Reply: No gains from Y-pipe?
