Power steering line question
I was checking out my power steering tonight because one of the lines comming off the resevoir was leaking. I traced the line to the front of the radiator area and all i saw was a hose linking the two lines together. (the two that comes off the resevoir.) is there supposed to be a steering cooler there or was it an option or is that supposed to be like that ??
![Wiggle](https://maxima.org/forums/images/smilies/wiggle.gif)
ill only bump once.....im curious to see if any other maxes 97-99 have that hose in the front you can see it by simply opening the hood its behind the pass side of the grill. curious to see if oyu have the bypass hose also or if you have some sort of cooler there......
On my 97 SE, it's a snakey cooling tube that runs from the passenger side all the way across the front of the rad and back. I looked at the parts fiche, and it appears that from 95-99 there are a couple of variations on the size/shape of this cooling piping. But there is no indication any variation involved a finned cooler with end tanks.
Dave
Dave
son of a b*t*h.....im gonna kill this guy that sold the car to me....told me it had no accidents well low and behold it was hit in the driver front now that i have had time to take the car apart and look close. they must have never installed it......well off to the boneyard !!
Originally Posted by Jime
I haven't seen one without it and I have had 4 Max's including a 2k2. Not sure where that diagram came from but mine is from the 99 FSM and it shows the aluminum one.
If you want to install the larger tube, go ahead it probably won't hurt anything. My point is that the currently installed equipment sounds like it's 100% correct.
Dave
scarletsosa
08-17-2015 09:09 PM
