buying a 95 with bad motor need a dek maybe
Old Jan 2, 2006 | 04:58 PM
95turbo gxe's Avatar
I was wondering how much diffrance is their in the vq30de and the vq30dek.
i got to buy a motor to put back in it and if its not too much trouble to put the dek in it I would just try that. OK whats the diffrance in the two motors I know the intakes are diffrant . Where does it get the extra 32 hp from. How much trouble is it to get it to go in and what tranny is it compatable with?
Old Jan 2, 2006 | 05:14 PM
RockfordMax's Avatar
Back from the dead
well the DEK is basically a DE, except it has a variable intake, if you were to get one, (assuming all hardware included) you would need a RPM controlled window switch to open the butterfly valves in the intake at a set rpm. Benefit of this is there isnt a power drop off at ~5000 rpm like the DE has. Only modification it requires (besides VI stuff) is resoldering the injector harnesses, it fits all transmissions the DE fits, and is a direct drop in.
Old Jan 2, 2006 | 05:21 PM
what ecu does it use? and how does the dek make 32 more hp than the de.
And does the dek do well with boost
Old Jan 2, 2006 | 05:28 PM
s0ber's Avatar
Most of the gains are from the 00VI, the DE-K is said to have different cams but not enough to have a noticeable gain, everyone has agreeed the extra HP is from the VI...
Most of the boosted folk <3 the DE-K for boost...
Uses the same ECU the 4th gen does.
Old Jan 2, 2006 | 06:00 PM
what do you mean by <3 the dek
where does the dek make peak power and torque?
where do the de make peak power and torque?
Old Jan 2, 2006 | 06:34 PM
motocross416's Avatar
he mean't they love the dek, for the top end power I would assume.
The dek picks up where the de starts losing power around 5000rpm. I would check check the dyno slips forum to see where the motors make the most power, there are plenty of charts in there.
Old Jan 2, 2006 | 06:36 PM
Back from the dead
yep. like i said, its a direct swap save for resoldering injectors and VI hookup. If you dont have one now, During the swap is the perfect time to do a 5 speed swap.
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
dcam0326
Sep 8, 2015 11:02 PM
Lowered_a33
Sep 1, 2015 07:49 PM
