antifreeze leak
Old Jan 3, 2006 | 01:54 PM
95GLEMAXX's Avatar
antifreeze leak
my max is leaking anti freeze from under where the coolant reservoir is. i know its not that bc i checked it.....what is on the bottom of the engine and right below where the reservoir tank is that could be leaking ...any ideas?
Old Jan 3, 2006 | 03:47 PM
Mxrider52's Avatar
I support for what?
Maybe it your waterpump it running down your block and running down the driveway or hoses
Old Jan 3, 2006 | 03:49 PM
kbmaxima's Avatar
check your hoses. i freaked out about my water pump too after seeing some coolant seeping down to my tranny pan area. ended up just being the upper rad hose. since it's getting cold, might as well change all the hoses and do a flush.
Old Jan 3, 2006 | 03:51 PM
95GLEMAXX's Avatar
well i just did a flush and all the hoses were checked..it is on the side near the water pump tho...but still not sure....gotta look at it in the daylight
Old Jan 3, 2006 | 03:52 PM
SMX95's Avatar
Most likely a bad water pump, get ready start saving up your dimes.
Old Jan 3, 2006 | 03:55 PM
95GLEMAXX's Avatar
around how much they cost?
Old Jan 3, 2006 | 03:58 PM
SMX95's Avatar
Depends if your doing this or a ASE CERTIFIED tech is doing it. Noticed I put ASE because I wouldn't let jiffy lube touch it. Don't have any idea on how much a new water pump will cost but factor in that the timing chain cover comes off, you will need to do an oil change again and a coolant flush. This can become very costly. Hopefully its done once and done right the 1st time.
www.allnissanparts.net
Old Jan 3, 2006 | 04:12 PM
jasonv's Avatar
timing cover doesnt have to come off to do a waterpump and ASEs dont mean d1cK. you can get a pump for around 70 bux
Old Jan 3, 2006 | 04:39 PM
96MajBlueMax
i just recently replaced my water pump, therm, and radiator all because i couldnt figure out where my leak was coming from but than eventually my car started overheating ...i changed the thermostat and radiator and check all hoses b4 attempting the water pump, but no luck i was still O/H. so i gave it a shot and attempted to replace the W/P myself and let me tell all of u MAX owners out "there", this is not an easy job! as i took apart the water pump cover, hoses, drivebelt tensioner, timing chain tensioner cover, etc., i noticed that i had to take off the timing chain tensioner as well, so that i did, but as i did that the little spring inside of it shot out into my oil pan, and i had no clue of where it was...so 3 weeks later, and $300 dollars later i have that problem fixed and my car does not O?H anymore, however now my car is not running right at all, my mechanic is saying im running on 5 cylinders and that the wire connected to my ECU for #2 cylinder is bad and he recommended that i replace the ECU unit and that everything should be fine. ANY SUGGESTIONS... PLEASE ANY HELP OUT THERE WOULD BE APPRECIATED GREATLY.
Old Jan 3, 2006 | 04:43 PM
96MajBlueMax
I Found An Ecu For $125 On Ebay But I Just Missed The End Of The Auction, If Your Stil Out There Let Me Know Im Interested.
Old Jan 3, 2006 | 05:23 PM
SMX95's Avatar
Try in the sale section
Old Jan 3, 2006 | 09:25 PM
jasonv's Avatar
yeah whatever you do you dont want to drop anything back there.
if the wire to the ecu is bad why would you change the ecu? wouldnt you need to change the harness? find out which wire that is and see if its just a loose pin. try to push it in and see if that helps.
Old Jan 4, 2006 | 04:11 AM
Preet S 22's Avatar
I30"T"
I just bought a rebuilt water pump from a store here called Advance Auto Parts (not sure if its a national chain). It cost me 35 plus 25 core. For those who want brand new...thier price was 55.....thats not too bad.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Mar 12, 2020 12:06 AM
fastcarny
Oct 12, 2015 07:06 AM
RWCreative
Sep 21, 2015 11:01 AM
