Possible trans-computer gone bad?
Well here's whats going on... i have a 98 trans with ~6k miles on it for about 6 months now.... and im still fighting with the trans not shiffting correctly... basically going 40 it feels like its locked in gear... if i press the gas gently the rpms dont move on the tach... it takes almost half throttle to get it out of gear.... now i know this aint normal... since both have the exact same problem would it be possible to have a bad trans computer...
by the way i get no codes and i have a new tps sensor and the throttle cables are tight....
Diagnosing anything, you would start off with the basics. check your trans fluid. Look around the trans make sure all wires are in and secure, if anything check for corrosion. Then I would throw a scanner on the car and get a live data stream on what's currently happening. It could even be a defect trans from the company or rebuilt gone wrong. Go back a few steps as well before this trans was the old one doing the same thing? If so you go from there. You got to start thinking like a mechanic now, your willing to diagnose your car you have to think of re-accurance, did it happen with the old trans, did you install this trans, did someone else do it... Ect Ect..
At 40 MPH, trans up to operating temp your torque converter is locked up.
A bit of throttle should unlock it and allow engine RPM's to rise.
Check the TPS adjustment.
Haynes manual will help you set it correctly.
Originally Posted by 96MajBlueMax
i just recently replaced my water pump, therm, and radiator all because i couldnt figure out where my leak was coming from but than eventually my car started overheating ...i changed the thermostat and radiator and check all hoses b4 attempting the water pump, but no luck i was still O/H. so i gave it a shot and attempted to replace the W/P myself and let me tell all of u MAX owners out "there", this is not an easy job! as i took apart the water pump cover, hoses, drivebelt tensioner, timing chain tensioner cover, etc., i noticed that i had to take off the timing chain tensioner as well, so that i did, but as i did that the little spring inside of it shot out into my oil pan, and i had no clue of where it was...so 3 weeks later, and $300 dollars later i have that problem fixed and my car does not O?H anymore, however now my car is not running right at all, my mechanic is saying im running on 5 cylinders and that the wire connected to my ECU for #2 cylinder is bad and he recommended that i replace the ECU unit and that everything should be fine. ANY SUGGESTIONS... PLEASE ANY HELP OUT THERE WOULD BE APPRECIATED GREATLY.
Hey newbe get ur own thread....wtf
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
