Crunched frame with jack
So I decided to jack my car up Nascar style today and put the jack under the from rail half way down the side of the car. As it got higher I crunched the rail. In short, did I do any really bad damage?
The damage is sort of stupid, but harmless.
There are reinforced sections of that rail which are strong enough for lifting - look closer to the wheels and use the 1-1/2" sections between the notches.
Dave
Dave
I know - I jack my car up all the time the correct way but I just needed to swap my passenger side tires so I thought this might work. There is a slight hump under the passenger seat but its no big deal. I just wanted to make sure I didn't bend the frame (well, I guess I did) and have the car not track straight or something.
What actually makes it worse is when you have a large chunk from driving in the snow (the stuff that stays stuck behind the front wheel, just at the corner by the front door area) on a lowered max and you run over a speed bump, pay no repsect to the ice/bump contact, and the damage from the jack is multiplied by 100.
I always jack from the rear axle or the engine cross member. There is a nice nub on the front of the cross member that is great to put a jack under. There are also 2 jack points just in front of the rear wheels and 2 more just behind the front wheels. Look in your owner's manual for more info on these. Always take your time and make sure you are jacking in a safe place or you will end up like many of us in this thread.
Diagram as posted by Jime in another thread:
REDinLV
Aug 15, 2024 12:30 AM
homewrecker
Sep 23, 2015 03:41 AM
Hdnseek
Sep 9, 2015 05:55 AM
Thats what I do NOW.
