Pics of 4th gens with Tein H-Techs???
I havent seen very many pics of 4th gens with the H-techs. Mainly the s-techs or others. Ive seen quite a bit of 5th gens with pics on H-techs but not many, if any... 4th gens. Can I get some posts of pics with 4th gens on H-techs?
I was thinkin about getting them. The ride may be a smidgeon better. It's basically like going from a GXE to an SE suspension, nothing dramatic. Just depends what you want. I can tell you this. I tried modding my wheels/suspension and went conservative. It was all good for about 1 month until I wished I did the full drop and went 18"
Originally Posted by anj109
cause why would you waist your money on a 1" drop
agreed. unless you busted your stock springs, it hardly seems like much of an upgrade from stock. a bit stiffer, but if you want a subtle drop and stiffer ride, I would think Eibachs would be the better option.
I also have them, I really love them they make the car look level instead of the face up a** down look, Oh and they ride really good. Plus they look good with bigger wheels. I have 18" by the way.
http://i4.photobucket.com/albums/y13...5/b095137f.jpg
Tokico - 1.25" front & 1.25" rear ( only come with struts)
H&R - 1.4" front & 1.3" rear
Eibach's -1.5" front & 1.3" rear
H-Techs - 1.6" front & 1.2" rear
Progress - 1.7"front & 1.5" rear (thanks Spadez 911)
CM canuck - 1.8" front & 1.8" rear
Sprint - 2.0" front & 2.0" rear
Zenn - 2.0" front & 2.0" rear
Intrax - 2.2" front & 1.5" rear
S-Techs - 2.2" front & 1.8" rear
K-sport - 2.2" front & 2.0 " rear
All info was taken from ebay ads
Originally Posted by max88q
Also, someone said it only lowers it an inch but Ive been reading it lowers it 1.6 in front and 1.2 in back. Is this true?
Originally Posted by Chunger
I had both Eibachs and Intrax on my car before the H-Techs... The H-Techs were "slightly" taller than my Intrax before them.
I have Progress springs with the AGX's and it is beautiful everyone who see's my car always has a question or a compliment and the ride is really good with the progress...you dont bounce everywhere....its a 1.7" drop in the front and 1.5" in the rear if im not mistaken
Originally Posted by Dubbya
I dont think that the Tokico info is correct. I think is more like 1.8 front 1.6 rear. I have the Illuminas and Tokico Red Springs.
How about compared to the Eibachs for ride height? Also how would you compare the ride (harsh/soft) of H-techs to Eibachs. I have a pal who looking at H-techs as he only want to eliminate the 4x4 look but still wants a soft ride.
I didn't "measure it" with all the springs to do a detailed comparison.. I would say Intrax are the lowest, then Eibach then the H-Tech but I changed other parts of the suspension during that time. I'm riding on modified (shortened) Konis up front and Motivational mounts on the rear. The rear Koni's are set to the lower perch position with the H-Tech, but on the "upper" position with the Intrax. I'm riding on 18" OZ Superleggeras with Continental 245/40 tires.
H-Tech ride is stiffer then SE springs as far as I can remember them. H-Techs are good for looks/ride quality, not autocrossing. You should buy the set depending on your needs (be realistic).
Hello Help !!!! I Got 1996 Maxima And I Wana Lower It And Liek 2 Month Ago I Put New Monroe Suspension In Front Can I Go Wd Them And Eibach Springs ? Or Im Gona Have To Change Em ? I Was Planing To Leave Monroe's In Da Front And Buy Tokico's For Rear , Illuminas
Please Tell Me If I Can Do That Or I Shud Buy All Set Of 4 Tokicos Shoks/struts ... Thank You
Originally Posted by JSutter
spring rates:
canuck 125f 255r
tokico 111-225f 148-295r
h tech 179f 252r
s tech 201f 280r
eibachs 166-275f 166-343 r
oem se 120f 200r
canuck 125f 255r
h tech 179f 252r
s tech 201f 280r
oem se 120f 200r
no, its the progressive rate increase. eibach doens not make ths sport line for the max. the companies usually dont list them like that, but they should. all of those aftermarket springs are progressive rate.
What is the tire size on the "new rim" pics?
What struts are you using?
How's the ride?
I'll have to consider the H-Tech's when I can afford a drop.
Is progressive better than non-progressive springs?
Because not everyone cares to for bone jarring ride or "plans" to be a racer...
Short version - they're a good spring for people who want a fairly comfy ride yet still good handling and no 4x4 look.
Check my homepage for pics with 17s. I have no complaints with them. Yeah the drop could be lower but I don't want to have to worry about scraping and have a harsher ride. Even if they are among the softer springs, the handling is still 10x better than stock
