question from a friend...
Old Jan 4, 2006 | 08:51 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
well i noticed this as well... well my friend jus bought a 1996 4th gen... paid 1500 for it... has 185k... drives nice smooth he bought it from another friend of ours and he hooked it up with a megan exhaust... i drove it today and the tach starts jumping around and slams from one side to the other... common problem... can it be fixed... wat to do...
Old Jan 4, 2006 | 08:57 PM
surfman21's Avatar
can you explain that one...
Old Jan 4, 2006 | 09:00 PM
KabirUTA13's Avatar
at steady speed of say 45 mph the tach goes from say 2500rpm to like 4352 2345 2112 0102 the needle bounces everywhere
Old Jan 4, 2006 | 09:06 PM
surfman21's Avatar
sounds like a loose wire/ground. i would tell ur firend to just pull his gauge cluster out and check all his wire connections, and make sure there all good and tight
Old Jan 4, 2006 | 09:07 PM
KabirUTA13's Avatar
arite.. cuz after a few bumps... it works and works fine... hmm
Old Jan 4, 2006 | 09:17 PM
konak85's Avatar
get a new cluster
Old Jan 4, 2006 | 09:20 PM
KabirUTA13's Avatar
thats one thing im tryin not to do... if its suttin as simple as a loose wire... i woodnt mind fixing... jus figured someone else had this problem as well
Old Jan 4, 2006 | 09:24 PM
matty's Avatar
Happend to my tach at around 130K....Order a cluster from car-parts.com or ebay.com, pull your cluster out, pull the cover off, there are 4 screws in the rear of the cluster that holds in the tach. Loosen them on both clusters and swap out the tach. Reinstall and youll be fine.
-matt
Old Jan 4, 2006 | 09:29 PM
KabirUTA13's Avatar
arite great... thanx
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
