Stick shift problem
Stick shift problem
My stick shift is not bouncing to the center where it supposed. when i pushed the stick shift all the way to the left, it stays there. The right side is just fine, it bounce the stick shift to the middle. Few questions, what do i need to replace? does it have a spring to bounce the stick to the middle? If it does, how do I fix this problem and how hard is it? Any input will be appreciated. Thank you.
mine is pretty much the same problem. my shifter, when pushed to the left (1st and 2nd) will return nice and smooth. but when i push it to the right, it takes much more force and is not smooth at all. is this also the spring? (is there a spring for both sides?)
The location of this spring is right above the cat to y-pipe connection, and is visible after removing the heatshield (5 bolts) from the undercarriage. Look at the 4th generation Modification FAQs, and search for the site for installing a short throw shifter. This site provides pictures of both where in relation to the car this area is, as well as a close up pic of the shifter assembly where you can see the spring that you need to replace. I might go find the link...
Ok, so I messed up. It is actually listed in the 4G how to's. Here is the link.
Click here
Click here
Click here
Click here
k, thanks for findin the link.
Yea yea I know the thread is old but I dont wanna start a new thread when this one has my exact problem in it.
But I was gonna ask does anyone know the part number for that stupid spring? Mine broke the other day.
wait... to the right is ok correct... then it CANT be the return spring.... the return spring works then you push the shifter to the right... somebody correct me if im wrong...
34573-40U00, $5.70 from Courtesy - http://www.courtesyparts.com/betasit...-p-347190.html
Mar 12, 2020 12:06 AM
