Sea Foamed TB, fuel and Crankcase and CEL popped up
Old Jan 6, 2006 | 01:07 PM
Hitmanforprez's Avatar
It wasnt there before, so obviously I'm thinking it had to do with the intake sensor I took off while the car was running so I could seafoam the intake manifold.
I tried to reset the ECU using the little screw on it, I turned it clockwise for 10 seconds, back for 10 seconds, clockwise for 10 more and then set it back to the start position. I don't know if it worked, the CEL is still there.
Old Jan 6, 2006 | 01:23 PM
nosispower's Avatar
Try taking it to Autozone, have them scan it and maybe reset the ECU. That solved the problem for me.
Old Jan 6, 2006 | 01:29 PM
buttonhook's Avatar
seafoam will cause your spark plug to foul while it is cleaning. it should clear up. but you can take it to autozone if you like.
Old Jan 6, 2006 | 02:28 PM
So my spark plugs are messed up now? I just changed them I hope not...
Old Jan 6, 2006 | 02:30 PM
I reset the ECU and the CEL is gone, but I still wonder about my plugs
Old Jan 6, 2006 | 02:31 PM
njmodi's Avatar
Do I get a tax break?
Your plugs are fine. Just
Old Jan 6, 2006 | 02:38 PM
steven88's Avatar
Need A Light?
what code did you come up with? don't tell me you resetted the ecu without pulling the code
anyway, I'm sure its just a random misfire code...I get it everytime I seafoam....and so does my other friend with a 2k2
Old Jan 6, 2006 | 02:42 PM
the_3d_man's Avatar
next time just use the Brake booster line like everyone else... and I know some people put it in the crankcase but I wouldn't...
Old Jan 6, 2006 | 03:23 PM
I dont know where the break booster is, and yes I reset the ECU without checking the code
Old Jan 6, 2006 | 03:34 PM
buttonhook's Avatar
not ness. most of then time it just causes a miss when you are using it and then once it is burned/used they work just fine.
Mahmuth
Aug 16, 2024 08:23 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
