coolant leak
Old Jan 9, 2006 | 02:11 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
coolant leak
.... its my friends 96 max... we did maintenance on it yesterday... hoses to oil change and fuel filter to pcv and freakin tranny gear oil... and now today after noon around 2... he has a coolant leak... he didn't drive it for a while... the alternator went out... so i don't know wat i cood be i checked around the hoses and wat not... nothing... i crawled up under the car and i see it drippin from the oil pan towards the edge face the radiator... any idea wat it cood be?
Old Jan 9, 2006 | 02:15 PM
NmexMAX's Avatar
dot dot dot ...
Keep looking
Old Jan 9, 2006 | 02:23 PM
KabirUTA13's Avatar
:-( i was hopin for more of a solid answer... im still looking!
Old Jan 9, 2006 | 03:05 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
How much of a leak is it? It could be your water pump, but it's hard to say based on your description. I had a bad leak there and had to get the water pump replaced. See this: http://forums.maxima.org/showthread.php?t=446663
Old Jan 9, 2006 | 06:43 PM
KabirUTA13's Avatar
would it be easier to change the water pump if i took the engine off the motor mount on the pass side and kinda jack it up a lil
Old Jan 9, 2006 | 08:41 PM
Dan's Avatar
Dan
That's how the chilton book says to do it.
Old Jan 9, 2006 | 09:06 PM
jasonv's Avatar
thats the only way to do it. change your timing chain tensioner while your at it.
although if it was your water pump i dont think it would be leaking so far up front. when my pump went it leaked in the back of my oil pan away from the rad. i think thats because theres a weep hole right on the side of the block.
Old Jan 9, 2006 | 09:13 PM
NmexMAX's Avatar
dot dot dot ...
Fixed... .
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
foodmanry
Sep 24, 2015 12:02 PM
Hdnseek
Sep 9, 2015 05:55 AM
