stock hood wobble
Old Jan 9, 2006 | 07:54 PM
kbmaxima's Avatar
stock hood wobble
i thought the oem hood was heavy as *****. while cruising around at 70 mph, i can see the hood trying to lift up from the front. Is there a way to tighten something up there? Is there the possibility an aftermarket 'oe' hood was put on and weighs differently from the factory ones?
Old Jan 9, 2006 | 08:16 PM
96blackmaxSE's Avatar
boost me.....
let me see it wobble, wobble girl shake it shake it.....anyway
yeah just buy a carbon fiber hood....
if not check to make sure the hood latch is going all the way through the square thing off the hood....i had a problem with mine, all i did was bend and pull a little and now its tight...no wobble, wobble
Old Jan 9, 2006 | 08:40 PM
jasonv's Avatar
get hood pins
Old Jan 10, 2006 | 02:00 PM
buttonhook's Avatar
raise the rubber stops on both sides of the hood and lower the latch and it should fix it.
Old Jan 10, 2006 | 02:05 PM
njmodi's Avatar
Do I get a tax break?
We have a WINNAR!!!
Old Jan 10, 2006 | 02:21 PM
kbmaxima's Avatar
thank you for the only meaningful reply.
Old Jan 10, 2006 | 02:25 PM
buttonhook's Avatar
not a problem just did that with mine! fixed it
Old Jan 10, 2006 | 06:07 PM
dgeesaman's Avatar
Maintenance Monster
Hmm, I've done both of those things and my hood still rattles in cold weather.
Any other suggestions? Does one of the bumpers tend to sag or get tired and need replacing?
Dave
Old Jan 10, 2006 | 06:38 PM
njmodi's Avatar
Dave
Dave - given that the bump-stops are rubber, I can imagine they both harden (in a compressed state) over time. My 96 hood doesn't rattle at all, even on the coldest days (sub-zero farenheit), on highways, bumps, etc. I would definitely check the bump-stops.
Old Jan 10, 2006 | 07:25 PM
boost me.....
My reply didn't help you...
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
jaydot901
Sep 29, 2015 01:18 PM
