Adding a 2 stage shock sensor, question.
Old Jan 10, 2006 | 05:26 PM
CRiME's Avatar
oem ftw!
Hey, I'm going to add a shock sensor to my stock keyless / security system. I found this great link in the How To's:
http://www.vqpower.com/v2/modules.ph...howpage&pid=13
But, the sensor that I'm going to install is a 2 stage sensor that includes a warn away trigger. Since it has this feature, the sensor has 2 trigger wires, one for stage 1, and another one for stage 2. The FAQ link says to attach the trigger wire to the yellow / black from the BCM, but since I have two trigger wires on my sensor, what should I do here? Should I tie both stage 1 and 2 into the yellow / black, or is there a different wire to which I should solder the stage 1 trigger?
Sorry for the noob question, and thanks for any help!
Old Jan 11, 2006 | 10:53 PM
96_vqmax's Avatar
Just pick one wire,which ever one you want,the stage 1 is like more sentitive,it'll trigger the alarm with the shock of less then .8 or .08 or less of of the second,and the stage two was .8 or .08 of a second or more,just try it out to your taste and see which one you like better,but not two together.Hope this help.
Old Jan 12, 2006 | 12:24 AM
CRiME's Avatar
oem ftw!
Thanks for the reply!
Old Jan 12, 2006 | 07:32 AM
97BlackSEGold's Avatar
i wired both of the wires to a toggle switch so i can choose whether i want the alarm to be normal or very sensitive, it worked out great actually
Old Mar 8, 2009 | 06:57 AM
hernameismina's Avatar
i need some help with mine
i installed all of it yesterday, but when i tested it out my alrm doesnt even sound when i unlock a door
Old Mar 8, 2009 | 09:39 AM
TLMNICK's Avatar
use the second stage, and just adjust the shock sensor as needed.
If you unlock the car with the key....it'll disarm the alarm...you have to unlock it from the inside lock. Also make sure that your stock alarm is arming.....once you lock all the doors (the doors, hood, and trunk must be closed)...lock the car, and see if the security light stays on solid for 30 seconds....after that 30 secs is up....then the stock system is armed.
There is also a security/theft fuse under the hood that'll stop the alarm from sounding if its blown.
KabirUTA13
19
Oct 17, 2015 02:15 AM
pears
Sep 18, 2015 05:25 AM
Stagnet04
Sep 14, 2015 11:28 PM
conansriver
Sep 11, 2015 10:26 AM
