what size tire for my sawblades?
Old Jan 11, 2006 | 06:00 AM
1HOTMAX's Avatar
what size tire can i go with for best all around?
i know stock is 205 65 15
can i go 225 65 15?
thanks
btw/ i'm gonna go with summitomo htz4
Old Jan 11, 2006 | 06:12 AM
MaximaSE96's Avatar
Maxima Owner
it would prolly be more like 225/55...thats an odd size only like 2 choices on tirerack......even 225/60 dont have the sumitomos....u will have better luck with 225/50 (smaller sidewall) or 215/60
i personally use HTRZs for summer
Old Jan 11, 2006 | 06:21 AM
1HOTMAX's Avatar
225 60 15 i meant
Old Jan 11, 2006 | 06:28 AM
MDeezy's Avatar
. . . . . . 215/65/15
Old Jan 11, 2006 | 09:23 AM
Tim96I30t's Avatar
215/60/15 good all around size. If you drive in snow you don't want to go too wide. The wider the tire the worse it is in snow and winter weather. Get a tire that fits your needs, I like Cooper Touring, not too expensive, wear great, and the ride is smooth and quiet. Just make sure you get road hazard, costs nothing, they don't fix flats, they replace the tire minus tread used.
Old Jan 11, 2006 | 09:57 AM
Donald199's Avatar
does 225/50/15 fits well?
Old Jan 11, 2006 | 10:26 AM
RA030726's Avatar
I'm nutty for Nissans
gxe/gle= 205/65
se= 215/60
225/50 will be bulging but will fit the 6.5" rim width. many people run with 225 wide drag radials. but they are rather short. definetly dont go wider.
Old Jan 11, 2006 | 12:34 PM
1HOTMAX's Avatar
gxe/gle= 205/65
se= 215/60
which one will give me less wheel gap.
Old Jan 11, 2006 | 03:56 PM
maximazation's Avatar
The 205/65R15 will give you a less wheel gap, but only slightly, because they are only 0.3" taller than the 215/60R15, but the 215/60R15 are slightly wider.
Old Jan 11, 2006 | 04:01 PM
nitromax's Avatar
with the 2 sizes JSutter gave, there is no real gap difference. slightly wider= 215/60. overall height will be very, very close, maybe a half inch more for 205/65.
Old Jan 11, 2006 | 07:11 PM
1HOTMAX's Avatar
what if i like it wide and tall?
215 65 15?
Old Jan 11, 2006 | 10:16 PM
86maxima96's Avatar
I Broke OT
go with 215 60 15
Old Jan 11, 2006 | 11:05 PM
El_Presidente
Just keep the OEM size of 205/65/15. Most knowledgeable people would agree that car makers are usually conservative with tires sizes, so if anything it could stand to be a little "tighter" on the wheel. If you go wider, the sidewall will just have less support and will be squishy and stuff.
Old Jan 12, 2006 | 04:44 AM
RA030726's Avatar
go look at some other cars. many domestic sedans (fords/gm/chry.) have 215/65 or larger. see if you like the look.
Old Jan 12, 2006 | 07:37 AM
1HOTMAX's Avatar
i would love to go 255/ wider is better but it will only go 215
Old Jan 12, 2006 | 09:26 AM
Donald199's Avatar
so 225 is too wide for the stock wheels?
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Garrettz459
Sep 28, 2015 02:50 PM
