P0140 after catback instalation
Old Jan 11, 2006 | 12:07 PM
WielkiWaac's Avatar
MaximaDriver
after i installed my greddy im getting P0140 code.
Haynes book says: downstream oxygen sensor high voltage fault.
i did some reaserch here and i couldn find anythink about that code in 4th gen maxima only 5th cali spec. mine is federal.
did i f....ed my o2 when i was installing my catback??
Old Jan 11, 2006 | 12:19 PM
njmodi's Avatar
Do I get a tax break?
downstream O2 sensor is the one after the catalytic converter...
You might have damaged it during the install.
Old Jan 11, 2006 | 12:25 PM
WielkiWaac's Avatar
MaximaDriver
is there any way that is connected incorectly??
Old Jan 11, 2006 | 12:33 PM
njmodi's Avatar
not likely - unless you broke a wire or pulled a wire out of the connector...
Old Jan 11, 2006 | 12:43 PM
WielkiWaac's Avatar
MaximaDriver
i will check it.
thank. i was confused because in 5th gen maxima P0140 – Heated Oxygen Sensor malfunction Sensor 2 Bank 1
Old Jan 11, 2006 | 04:36 PM
Zack342's Avatar
I have that code also and i don't have a O2 in my cat....
Old Jan 11, 2006 | 04:39 PM
njmodi's Avatar
Maybe you have the code because the o2 sensor is missing...
I believe EVERY 4th gen is supposed to have a post-cat o2 sensor. It doesn't do much (unless both front o2 sensors are not working)...
Old Jan 11, 2006 | 06:05 PM
WielkiWaac's Avatar
MaximaDriver
in my 99 max O2 sensor is behind cat
Old Jan 12, 2006 | 12:59 PM
Zack342's Avatar
nope not cali-spec cars
Old Jan 12, 2006 | 04:34 PM
ManualMaxima's Avatar
5th Gen till she dies!
all 4th gens have at least 2......downstream is on or after the cat....and it is the same code for 5th gens....the heated part des not mean anythign teh oxygen sensor is still bad in the back....the heated part is that the 02 sensors heat themselves up.....bank 1 is teh side that cylinder #1 is on, and sensor 2 is downstream
KabirUTA13
19
Oct 17, 2015 02:15 AM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
220k+ A32
Sep 11, 2015 02:18 AM
Maxboy23
Sep 4, 2015 06:04 PM
