Brake light problem. HELP!
Old Jan 13, 2006 | 05:26 PM
lordaphex's Avatar
hey guys I need some help. Today I got off of work and my brake light on the instrument panel was on. the e-brake is not engaged, i checked it multiple times. why would that happen and how can i fix it? thanks
Old Jan 13, 2006 | 05:28 PM
njmodi's Avatar
Do I get a tax break?
Low brake fluid most likely. If it is low, check for leaks and pad wear. Typically if the fluid is low in the reservoir, your pads are worn and it may be time for replacement.
Old Jan 13, 2006 | 05:44 PM
s0ber's Avatar
Indeed, bad alternator will shoot out a brake light as well correct?
Old Jan 13, 2006 | 05:46 PM
lordaphex's Avatar
not sure about the alternator s0ber but the brake fluid i just checked does seem a tad low. and i think my pads are about done also. how long do i have? can i just add fluid until i can get my pads and rotors done?
Old Jan 13, 2006 | 06:24 PM
njmodi's Avatar
Bad alternator will show brake light and battery light at the same time (well that indicates a charging system fault -> most likely a bad alternator)
Old Jan 13, 2006 | 06:25 PM
njmodi's Avatar
No way to tell how long you have... it depends on how you drive, etc.
Old Jan 13, 2006 | 10:42 PM
Digitized's Avatar
actually, it happened to my sentra, my brake light came on, all brakes are fine, e-brake fine, battery light not on...eventually battery light came on when I just had no more juice in it
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
Samedi
Aug 13, 2015 04:05 PM
