Replacing belts
Old Jan 17, 2006 | 09:43 AM
thisasian's Avatar
Replacing belts
The belts are squealing, esp. on cold mornings, and my steering feels kind of funny when the car hasn't had time to warm up. I figure the belt for the power steering pump is over-stretched, and I'll have to replace the belts soon. Anyone know what size belts to buy? And maybe what to check for to make sure I have to replace them? I don't want to tighten the belt tightener just yet, for fear of the belt snapping.
Old Jan 17, 2006 | 09:50 AM
descent's Avatar
mine also squeal before the car is fully warmed up. is it possible to just grease it?
Old Jan 17, 2006 | 09:58 AM
thisasian's Avatar
Na, they're gonna squeal either b/c the belts are worn and they have no grip = replace them, or they're loose and they don't have enough friction = replace or tighten.
Belts exist to turn something, powersteering pump, a/c, superchargers, etc. using the power of the engine to turn them. They need friction to turn the wheel/pulley of the part in question. Grease is the anti-friction, and although that would make the noise go away, it would not make the problem go away, Young Maxima-Padawon.
Old Jan 17, 2006 | 10:00 AM
MaxKlinger's Avatar
Just replace them, they're not that expensive. The outer belt (main belt) which drives the A/C compressor and alternator, is very easy to change. The inner one is a lot trickier because you have to pivot the power steering pump to release the tension. I accidentally broke the adjuster bolt when I did this, what a pain! If you have it done, the labor probably isn't that much. Just don't wait around, it will either leave you stranded or worse! I almost got into an accident with a school bus once because my PS belt slipped and I couldn't turn in time.
You can put on belt dressing but that's only a temporary solution. Just buy new belts and put them on.
Good luck, guys!
Old Jan 17, 2006 | 10:01 AM
njmodi's Avatar
Do I get a tax break?
Sizes - any auto store will have the right sizes - they can look it up.
Belts should be changed every 60k...
If you don't know when the belts were last changed, just change them...
Old Jan 17, 2006 | 10:58 AM
Dubbya's Avatar
VK56 Inside
They are not expensive, even for the good belts (good year gatorgrip).
Old Jan 17, 2006 | 12:59 PM
Addicted2Bass's Avatar
i had my belts replaced about 2 weeks ago and they started squeling pretty much right after being replaced....the old, worn out ones did not. It's really cold out now, if that makes any difference
Old Jan 17, 2006 | 01:01 PM
njmodi's Avatar
Your belts are incorrectly tensioned. Go have them tightened and that will take care of it.
Old Jan 17, 2006 | 01:06 PM
is there a specific torque they need to be tightened to?
Old Jan 17, 2006 | 01:07 PM
njmodi's Avatar
1/2" deflection with 15lbs of force at the middle of the longest span.... or something like that... just tighten it a little at a time until it stops squealing... the mechanic should know what to do.
Old Jan 17, 2006 | 04:48 PM
ManualMaxima's Avatar
5th Gen till she dies!
Good luck, guys!
i did the same thing, broke my tenstioner bolt.....just go any autozone and they will get the corrct sizes for you
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
boomerbrian
Sep 4, 2015 08:25 AM
