sloppy steering at highway speed, bump steer??
Old Jan 17, 2006 | 02:41 PM
SuperFishstick's Avatar
I've had this problem for a while now. Steering is sloopy, and vague and car seems to go where ever it wants to. Sometimes its hard to keep it inside the lane on the interstate. I have kyb's with eibachs, had the lower ball joints replaced, outer tierod replaced and the front wheels alligned. From what i can tell, my motor mounts are shot ( will replace those soon ) as well as my axles will be replaced as well, but i don't think thats the issue. The only thing that i can think of is that my steering rack bushings are shot and the steering rack is moving around, or my wheel bearings are shot, ( i do hear a slight whine ). Any input will be greatly appreciated.
Old Jan 17, 2006 | 02:56 PM
MDeezy's Avatar
if you axles arent bad, keep the $300 you'd spend. No need to replace them if they are in good condition.
Replacing the inner tie-rods could cure it. I have the same thing but expect an alignment, inner/outer +all bushing replacement to cure the sloppyness.
Old Jan 17, 2006 | 02:59 PM
incognito903's Avatar
i dont have any suspension parts upgraded but before i joined i read that the max has seriously sloppy steering to begin with
Old Jan 17, 2006 | 03:03 PM
i've got a torn cv joint boot, and i don't know how long its been torn. One was torn and i had it replaced, but when i turn wheels , i sometimes hear a clicking noise, so its better just to get new axles.
Old Jan 17, 2006 | 03:10 PM
dgeesaman's Avatar
Maintenance Monster
There is a very good chance your axle damage is causing the bump steer. I would wait until that is fixed before passing judgement on the steering issue.
If the axle does not fix it, a basic inspection will catch:
- worn inner tie rods
- worn outer tie rods
- worn rack bushings
- worn out strut mounts
- worn components in the swaybar assy
Have the mechanic (or you) look very closely and wiggle/pry/shake things to inspect for loose components.
Dave
fastcarny
Oct 12, 2015 07:06 AM
Bluenissan
Sep 20, 2015 08:54 PM
Bonka
Sep 14, 2015 11:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
