Running amp power through firewall HELP!?!
Old Jan 17, 2006 | 03:08 PM
GTRBlkMax97's Avatar
http://forums.maxima.org/showthread....14#post4643014 please help trying to wire my new system
Old Jan 17, 2006 | 03:14 PM
Mxrider52's Avatar
I support for what?
Jack up the car and take off the left wheel and then take off the black plastic cover to the back of the fender well and there will be a hole big enough to squeeze your wire through . This is what I was told I havent attempted it.
I see your from Knoxville. You gonna go to the nashville meet on 3/25/06? Maybe we can hook up and travel as a group if I can go.
Old Jan 17, 2006 | 03:17 PM
InsneDrmr's Avatar
You can try the method listed above...or you have to drill a hole in the firewall...thats what i did.
MaximaSE96's Avatar
Maxima Owner
i drilled....and used a grommet
Old Jan 17, 2006 | 03:19 PM
Dubbya's Avatar
VK56 Inside
There is already a suiteable hole. I will get a picture of it tonight and post it up tomorrow. This is where I ran the wires for my RPM switch and my City Lights Switch back into the cabin.
Old Jan 17, 2006 | 04:47 PM
99grnmaxgxe's Avatar
There should be a small area under the brake fluid resevior to drill.
Old Jan 17, 2006 | 04:50 PM
Vagabond's Avatar
My buddy put it thought the door frame opening and up through the driverside hood opening where it meets the body. Right in the corner. you have to cut the little boot on the cables in the door.
Old Jan 17, 2006 | 05:46 PM
DcMaN's Avatar
hahahah wtf is wrong with people these days. No common sense running a wire through the door frame???? Jack up the car turn the wheel so you can access the plastic lining, remove it and you will notice a grommet which you can feed any size power wire though.
Old Jan 17, 2006 | 06:41 PM
BigLou93SE's Avatar
I'm going to try again, I hate this resizing bs.
So apparently, it ain't getting bigger. I even used the original pic size...oh well. You can see the general direction, follow the red amp wire into the firewall, and there used to be a black rubber grommet. This car that's pictured is a 96.
I forget who sent me that pic, but it was a big help. There is a grommet in this place.
Old Jan 17, 2006 | 06:43 PM
descent's Avatar
yea there is a hole u guys, with a gromet and everything. ill get a pic tomorrow
Old Jan 17, 2006 | 07:13 PM
tikiboom's Avatar
I need an intervention
i drilled too..couldnt find the damn grommet everyone talks about
spent 1 hours lookin for a grommet and 2 mins drilling ,go figure
Old Jan 17, 2006 | 08:59 PM
KsuMax's Avatar
Cheesing away...
I Just drilled a hole
Old Jan 18, 2006 | 10:10 AM
descent's Avatar
here's the factory hole
Old Jan 18, 2006 | 10:42 AM
Dubbya's Avatar
VK56 Inside
Beat me to it. Thats where I ran my wires.
Old Jan 20, 2006 | 11:21 PM
that's where my 97 had a hole but my 99 didn't but i figured it out so not a problem now thanks guys, my **** KNOCKS NOW
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
