Custom Sidemarker lights
Old Jan 19, 2006 | 11:18 PM
Cdg2125's Avatar
Anybody custom added sidemarker ligths to your max? I want to install some on my 98 SE but i'm a little sketched on how get them on and where to attach wires. Any info on how you did it or a thread on the .org would be great. Thanks alot!
Old Jan 19, 2006 | 11:28 PM
DR-Max's Avatar
You gotta drill into the front fenders, and tap off of the side portion of the bumper lights. I think that look is played out, this was in back in the mid 90's.
Old Jan 20, 2006 | 05:54 AM
maxgtr2000's Avatar
KH3 by popular demand
I like the look, and it is a safety thing too, one time a while back I was getting over and someone was getting over at the same time, and if you or the other person isn't paying that much attention you will meet, epsecially if you are looking further down the road. One the same note when I look over sometimes and I see an jetta or something I know they are getting over beside me when I see the blinker. A neccessity, no, more of function for me.
Old Jan 20, 2006 | 01:16 PM
JPMax's Avatar
What's next!?..
I installed a set last year on my car.
looks nice and has been very helpful in heavy traffic.
1. drill holes in the front fenders (measure carefully so they're even)
2. ground wire can be put under one of the fender screws under the hood
3. splice the power lines to your turn signal lights in the bumper
Old Jan 20, 2006 | 02:07 PM
RA030726's Avatar
I'm nutty for Nissans
member ludacris has some on his car. his cardomain is stillennismo or something like that. they look pretty good in line with the side molding.
Old Jan 20, 2006 | 07:26 PM
venompwr2's Avatar
I have them on one of my Max's, it's very easy to do really. Drill a hole of appropriate size to fit the side marker into the fender, or wherever you are mounting it. I ran the wires up over the fenderwell lining up to the front turn signal, and use wire taps to get power from the turnsignal wires, and thats it really.
Old Jan 21, 2006 | 12:32 AM
Poowill's Avatar
Yeah, i want to do this as well. But where are you getting the light?
Old Jan 21, 2006 | 03:13 AM
Cdg2125's Avatar
I was thinking of ordering lights from JCWhitney that fit either the VW or Audi. Different options of lights(flat/raised, oval/square) so it seemed they would work.
Old Jan 21, 2006 | 07:43 AM
venompwr2's Avatar
They are all the same, its just a light with 2 wires, very simple. I bought mine from pepboys and I just changed the bulbs inside to led's.
Old Jan 21, 2006 | 07:52 AM
old_G22's Avatar
i did mine like venom,but if i had to do it again,i would relocated it lower. have it line it up with the door protecter thingy.
Old Jan 23, 2006 | 09:34 AM
Cdg2125's Avatar
yeah i couldnt find the clears at pepboys. They only seemed to have colored markers (red or orange). What do you think for placement? I was thinking inbetween the handles and the door strips? Any thoughts?
Old Jan 23, 2006 | 05:40 PM
isawyou's Avatar
I installed these on one of my previous cars (a first generation Dodge Intrepid and loved it. I put them in line with the side molding and it looked great!). You seem to be doing it in the interest of safety, so I recommend wiring one wire to the parking light + and one to the turn signal +. This way, they will be on with your lights and flash with your turn signals (though the flash will be opposite of your signal when your lights are on -- much like the front side lights of many GM vehicles)
Old Jan 23, 2006 | 05:44 PM
njmodi's Avatar
Do I get a tax break?
venompwr2 - thats a nice clean install
Old Jan 23, 2006 | 08:10 PM
Cdg2125's Avatar
anybody know what colors the turn signal wires are?
Old Jan 23, 2006 | 08:13 PM
sickmax's Avatar
aaron lavigne FTG
the wires are BLACK lol
Old Jan 23, 2006 | 08:21 PM
Cdg2125's Avatar
haha thats what i was guessing. I was just hoping they might be yellow or something so i couldnt screw it up lol.
Old Jan 23, 2006 | 08:30 PM
JPMax's Avatar
What's next!?..
I think the power lines have a color tracer on them and the ground wires are just solid black.
It's been several months, I'll have to check tommorow.
Old Jan 24, 2006 | 06:17 AM
ManualMaxima's Avatar
5th Gen till she dies!
just run a wire formt the side marker to the front blinker bulb harness........that is all yo have to do....it is 2 wires on oth not real confusing. i used one of those things from home depot which you drill a hole, then you use acone shaped tool on a drill to make the whole larger to fit the side marker in it. Make sure you donot do it to high up cause it will look terriable, and make sure they are level
Old Jan 24, 2006 | 07:23 AM
Cdg2125's Avatar
sounds easy enough. I think im buying the lights this weekend so I'll post how it goes later on. Thanks for the help.
Old Jan 24, 2006 | 05:15 PM
venompwr2's Avatar
They should have them in with the aisle that has all the neon lights and blue headlight bulbs and that stuff. Same with advance auto parts. Or just find them online somewhere.
Old Jan 24, 2006 | 06:36 PM
Cdg2125's Avatar
sounds good venom. I'll check the stores this weekend. Am i gonna need to cut around the hole i drill to get the lights close to flush or no?
Old Jan 24, 2006 | 10:51 PM
JPMax's Avatar
What's next!?..
Try to find universal lights.
They only need the one hole to sit flush with the fender.
If you can't find them locally, heres a few sites with several.
http://www.stylinconcepts.com/parts....categoryID/315
http://www.autoaccessorystore.com/ho...product=168&s=
Old Jan 25, 2006 | 05:23 AM
venompwr2's Avatar
No you shouldnt, there is about an inch long "stud" if you will, that comes out of the back of the lense, where the bulb sits in. That's what goes into the hole you drill. The rest of the lense is flat, so as long as you are mounting it on a flat location it should be flush just fine once you put it in place.
Old Jan 25, 2006 | 09:46 AM
Cdg2125's Avatar
thanks alot guys i really appreciate the help!
Old Jan 25, 2006 | 09:56 AM
Cdg2125's Avatar
ok sry one more question! how did you attach the lights to the car? appoxy or like 3M tap?
Old Jan 25, 2006 | 03:13 PM
sunten1
I would just use taps and then tape them up so water doesn't get in...
Old Jan 25, 2006 | 05:02 PM
venompwr2's Avatar
I used epoxy on the back of mine, so they are pretty much stuck there. But the ones I have, also have 2 smaller holes to drill into the fender and attach it with screws. The epoxy has worked fine for me, they've been on the car for over 2 years.
Old Jan 25, 2006 | 05:12 PM
Cdg2125's Avatar
ok thanks venom
matts95max
Apr 23, 2025 10:44 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
dcardello
Sep 3, 2015 11:44 PM
iflexsteel
Sep 2, 2015 08:04 AM
