HELP!! Car Won't Start
Old Jan 24, 2006 | 01:25 PM
Camry343's Avatar
I got a code for the Knock Sensor and/or Knock Sensor circuit. I changed the knock sensor cleared the code and now the car won't start. I never had any starting issuses before changing the sensor and I've checked over everthing I had unplugged to change it at least three times. I've changed this sensor before on other maximas but, I never had this happen to me, so I'm a bit confused. Could I have done something wrong? There are currently no codes. The car just cranks and cranks but won't start. Any info would greatly help. Thanks.
Old Jan 24, 2006 | 01:34 PM
njmodi's Avatar
Do I get a tax break?
Maybe you left one of the harness connectors unplugged.. go check all the stuff you touched.
Old Jan 24, 2006 | 03:35 PM
Camry343's Avatar
checked and rechecked. Everything is plugged in.
Old Jan 24, 2006 | 03:39 PM
THEJEFFERATOR's Avatar
how did you clear the code ? if you turned the ecm screw, did you turn it back?
Old Jan 24, 2006 | 03:55 PM
Camry343's Avatar
I used my snap-on scanner.
Old Jan 24, 2006 | 04:32 PM
Papa Squat's Avatar
check your fuses make sure you didnt blow one
happened to me a coupe weeks ago
Old Jan 25, 2006 | 02:32 AM
Camry343's Avatar
Well with the scanner I made the fuel pump come on, so I know that's working. I'll check the rest of the fuses today.
Old Jan 26, 2006 | 11:22 AM
clifford's Avatar
Did you get it fixed?
My car won't start either.
I'm a noobie and my account isn't allowing me to create a new thread.
The problem I'm having is:
I turn the key in the ignition and nothing happens. I have electrical power but the starter doesn't even try to turn. I checked all fuses inside the car. I also tried to jump the battery. Still nothing. I'm pretty bummed right now. Seems like there is no signal going to the starter. I don't know what to do. Any ideas? Please help.
Thanks.
Old Jan 26, 2006 | 11:24 AM
njmodi's Avatar
Thanks.
Do you have power at the starter or you just mean that the car battery is fine and the lights/etc work?
If you don't get any voltage at the starter, then it's most likely the ignition switch.
Old Jan 26, 2006 | 11:26 AM
clifford's Avatar
The car battery is fine. I get lights, radio, etc...
How do I test voltage to the starter?
Old Jan 26, 2006 | 11:41 AM
clifford's Avatar
I would do a search in the forum but my account won't allow me. Waiting on activation? I just signed up today.
Old Jan 26, 2006 | 11:42 AM
njmodi's Avatar
Pull the connector, get a multimeter, turn the key to start and see what you get. And you don't get search privileges without donating.
You can also try give the starter a few whacks and then try to start the car ... that often works.
Old Jan 26, 2006 | 11:53 AM
clifford's Avatar
Donations -- guess I'll be doing that soon.
If I tap the starter and that fixes it, does that mean the problem was all in the starter or do I still need to explore the ignition switch?
Old Jan 26, 2006 | 11:55 AM
njmodi's Avatar
If it starts after a bang on the starter it's time for a new starter. If it still doesn't start, then it's still undecided and you'll have to do some further checking.
Try jiggling the key around in the key-slot and see if that works. If that does, then it's most likely the ignition switch.
Old Jan 26, 2006 | 12:02 PM
clifford's Avatar
Thanks for your input.
This is my first maxima that I just purchased -- used.
Is it normal to have the clutch pressed in order for the car to start? I think I recall having to do this when it was starting. Yes, it's a manual.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
